3 Pulse programmable relay
jarodmitchell
Posted: May 19, 2017 at 10:01 AM / IP Logged Link to Post Post Reply Quote jarodmitchell
Hi I'm trying to figure out how to build or where to buy a pulse relay that will send out one momentary 12v pulse only after receiving 3 pulses in a row, the idea is to make it so I can hit unlock on my car 3 times sending out power to the electric fuel door opener so it opens up without me having to go inside the car. Any help would be greatly appreciated
Jarod
Platinum - Posts: 7,783
Posted: May 21, 2017 at 8:31 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is one possibility using a flexible and readily available module :
You could use a PAC TR-7 module for this. These modules cost under $20 and can be programmed to do various
functions. Here is a link to the TR-7 Guide : https://www.the12volt.com/installbay/file.asp?ID=1031
See Feature #14. You could use the (+) drivers door lock motor wire as an input on the TR-7's Green wire.
Then program the TR-7 for Feature #14 with 3 input pulses within 5 seconds to get a (+) output pulse on the
Blue wire rated at 4 amps to control the fuel door relay ( or a (-) 150mA pulse on the White wire ).
jarodmitchell
Posted: May 21, 2017 at 10:00 PM / IP Logged Link to Post Post Reply Quote jarodmitchell
Thank you so much!!!
Jarod
shift_happens
Member - Posts: 45
Posted: May 23, 2017 at 11:16 AM / IP Logged Link to Post Post Reply Quote shift_happens
Metra TRIGGER has a poop ton of programmable features.
http://www.metraonline.com/part/TRIGGER
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
