Problem with Autowatch 695
jimboben
Posted: May 25, 2017 at 12:30 PM / IP Logged Link to Post Post Reply Quote jimboben
Hi,
I am having a problem with the alarm faulting immediately after the arming period ends.
The alarm is fitted to a 2012 Fiat motorhome and is activated by the Fiat remote key. It has 2 wired air movement sensors mounted on the dashboard, a wireless movement sensor on the ceiling in the rear and a wireless magnetic sensor on the caravan door.
Since installation when new, it has worked fine but on a recent trip I was unable to arm the alarm. The problem started at the same time as the Power Supply Unit to the caravan area partially failed but I can't see the connection as the alarm is wired to the engine battery and the PSU is powered by the leisure batteries.
The PSU has been reprogrammed and is working correctly and I have renewed the batteries in the wireless sensors.
I would appreciate any guidance as to what else to do.
Thanks James
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
