1998 Dodge ram keyless
rlg4675
Posted: June 24, 2017 at 1:25 PM / IP Logged Link to Post Post Reply Quote rlg4675
I admit I am stumped, I bought a no-name keyless entry from Ebay to install in my old 98 dodge ram 1500. I also bought two 775 relays due to the reverse polarity door locks.
I have searched the internet for hours trying to find answers. The system I bought is very basic and only is a keyless entry. It will do either positive or negative triggering.   The problem I have is there to spice into the factory wiring system? Some people have stated go into the drivers side kick panel to access the orange/purple and the pink/purple wires. Some others say go into the door itself, between the switch and the unlock actuator, while another post has a guy going into the body control module wires under the dash(this is only on the highline model module) which mine is not so that one is ruled out.
so do I go it to the door between the switch and the actuator? will this work to unlock the p/s side too? or do I have to run wires all the way to the other door too?
Or do I go in through the drivers side kick panel to control both sides? My truck has power door locks with out any factory keyless entry and the drivers side switch un locks both doors at the same time which is all I am looking to do.
Thanks for any help
rlg4675
the12volt
Administrator - Posts: 3,955
Posted: June 24, 2017 at 4:27 PM / IP Logged Link to Post Post Reply Quote the12volt
I would tie into the orange/purple and the pink/purple wires in the driver's kick panel. You'll have to cut each one to wire them correctly as shown in this diagram:
1998 Dodge ram keyless - Last Post -- posted image.
https://www.the12volt.com/relays/relaydiagram3.html
This will control all doors.
1998 Dodge ram keyless - Last Post -- posted image. the12volt • Support the12volt.com
rlg4675
Posted: June 24, 2017 at 5:21 PM / IP Logged Link to Post Post Reply Quote rlg4675
Yes that works !, Thank you so much I was stumped by other wiring diagrams that showed a completely different way to wire it.
Thank you again!
rlg4675
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
