use alarm as a keyless entry only system?
andyh24
Member - Posts: 9
Posted: June 28, 2017 at 12:10 AM / IP Logged Link to Post Post Reply Quote andyh24
I have a 2000 Camaro with a viper 600 esp alarm. It currently has a proximity and shock sensor attached to it. I no longer want the alarm part, I just want to use it for keyless entry. Can I remove the sensors and siren and just use it as keyless entry ony?
Platinum - Posts: 13,667
Posted: June 28, 2017 at 7:28 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Remove the sensors and disconnect the door trigger wire. When you disconnect the door trigger wire do it in a way that you can easily reconnect it. You have to have it connected if you need to program any features.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
