won't enter reservation mode after reset
ajent
Posted: July 14, 2017 at 7:32 PM / IP Logged Link to Post Post Reply Quote ajent
Hello,
I mistakenly pushed the wrong buttons on my pro t11 remote trying to program the compustar cm7000 so I reset everything back to default to be safe.
Instead it seems to have broken my reservation mode. The car stays running when I exit, but then the motor shuts off & doors lock but security doesn't arm and does not finish reservation mode.
Any idea what options should be changed on the cm7000?
Manual 2015 STi with push button start.
Thank you
dswift
Copper - Posts: 396
Posted: July 19, 2017 at 11:23 AM / IP Logged Link to Post Post Reply Quote dswift
With a push to start ignition system, the installer should have changed Option 01-06-02.
So when you park, you engaged the E-brake and then you basically autostart the car. Then when you can get out and close the door behind you, the car will either lock the doors then shut down, or shut down and lock the doors.
"dont ground out!"
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
