Ammeter Shunts And Ground Loops
couchflambeau
Posted: March 23, 2026 at 3:56 AM / IP Logged Link to Post Post Reply Quote couchflambeau
Hello all,
I'm in the process of installing a large audio system and installed a shunt on the ground side of my amplifier rack which then goes to a common piece of 2/0 wire that goes to my chassis ground in the back of the car.
Im noticing an alternator whine with the car running. I believe the shunt is rated as 200mV.
Can the shunt resistance be causing a ground loop?
lee.lopez
Copper - Posts: 319
Posted: March 24, 2026 at 10:04 PM / IP Logged Link to Post Post Reply Quote lee.lopez
I wouldn't know if that's the cause or not.
I would run a jumper wire from your head unit ground to your amp ground and see if that gets rid of it. That's worked for me in the past when even ground loop isolators failed.
couchflambeau
Posted: April 04, 2026 at 5:47 PM / IP Logged Link to Post Post Reply Quote couchflambeau
Certainly can't hurt.... I'll give it a try!
Monday, August 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
