03 Envoy Remote Start Wiring
jmoncada
Posted: October 20, 2003 at 9:41 AM / IP Logged
need wire info for 03 envoy, to install remote start, any info will help. thanks
Z32tt
Member - Posts: 17
Posted: October 28, 2003 at 11:49 PM / IP Logged
|              12V|red  (x2)           |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #455G *3       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |relay box under rear seat   |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|gray/black          |   |headlight switch            |
|       HEADLIGHTS|white               |-  |headlight switch            |
|     DOOR TRIGGER|gray/black          |+  |underdash lt or dri A pillar|
| DOME SUPERVISION|comes on with disarm|   |                            |
|  TRUNK/HATCH PIN|pink/black *1       |-  |liftgate module             |
|         HOOD PIN|pink/black          |-  |pin switch or BCM           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|white               |   |blue plug, pin 49 @ PCM *2  |
|      SPEED SENSE|GREEN / WHITE         |   |blue plug, pin 32 @ PCM *2  |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black or blk/yel    |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |driver door module          |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |front passenger door module |
|  LR WINDOW UP/DN|blue - brown        |A  |LR window switch            |
|  RR WINDOW UP/DN|blue - brown        |A  |RR window switch            |
| SUN RF OPN/CLOSE|blue/red - blue     |A  |sun roof motor              |
|        RADIO 12V|orange              |+  |radio                       |
|     RADIO GROUND|BLACK/ white         |-  |radio                       |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|BROWN / white (dimmer)|+  |radio                       |
|    POWER ANTENNA|gray                |+  |radio                       |
|       LF SPEAKER|tan - gray          |   |radio                       |
|       RF SPEAKER|lt. green - green   |   |radio                       |
|       LR SPEAKER|brown - yellow      |   |radio                       |
|       RR SPEAKER|blue - lt. blue     |   |radio                       |
Notes:
NOTE:  This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555L.  *1 The liftgate glass ajar switch wire is purple. It is also located at the liftgate module in the liftgate.  *2 The PCM (Powertrain Control Module) is on the driver side of the motor.  *3 If Directed module part #455G is not available, refer to directfax document #1053.
jmoncada
Posted: November 04, 2003 at 3:01 PM / IP Logged
thankz z32tt. i will let you know if it all works.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
