2001 Astro Passenger Van
Welcome Guest :)
tgoodwin11
Member -
Posted: July 19, 2002 at 1:14 PM / IP Logged
Need the wireing setup for installing GM keyless entry kit.
Tom G
Moderator -
Posted: July 19, 2002 at 2:31 PM / IP Logged
Chevrolet | Astro Van | 1996-2002 |
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | YELLOW | IGNITION SWITCH HARNESS ** |
Ignition #1: | | | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | | WHITE | IGNITION SWITCH HARNESS |
Ignition #3: | | | N/A | IGNITION SWITCH HARNESS |
Accessory: | | | ORANGE | IGNITION SWITCH HARNESS |
Brake Light: | | | WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | WHITE | AT IGNITION COIL * |
Parking Lights: | | | BROWN (+) | AT HEADLIGHT SWITCH |
Headlights: | | | YELLOW (+) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | N/A | IN SCHEMATICS |
OEM Alarm Arm: | | | N/A | NO OEM ALARM PRESENT |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * Ignition Coil Located On Top Of Engine Behind Generator.** 1998+ Vehicles Are Equipped With GM's PASSLOCK II Anti-Theft System |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | RED (2) | IGNITION SWITCH HARNESS |
Starter Kill: | | | YELLOW | IGNITION SWITCH HARNESS ** |
Ignition +12 Volts: | | | PINK | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | PURPLE (-) | AT ANY PIN SWITCH **** |
OEM Horn: | | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | | L BLUE | DRIVER'S KICK PANEL***** |
Power Unlock: | | | WHITE | DRIVER'S KICK PANEL***** |
Trunk Release: | | | L GREEN (-) | AT REAR WINDOW RELEASE SWITCH |
Alarm Input Wire: | | | PURPLE (-) | AT ANY PIN SWITCH **** |
Notes: | | **** WHITE (-) At Courtesy Light Can Also Be Used For Door Trigger.***** Positive Pulse Door Lock Diagram. |
francotortora
Member -
Posted: October 07, 2002 at 12:10 AM / IP Logged
Hey do u know what wire is the pulse or the park brake?
thanx
Moderator -
Posted: October 07, 2002 at 9:47 AM / IP Logged
Look at the arm that the parking brake is on and there will be a wire coming off this arm. This is the wire you want.
Thursday, April 25, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
