Same as 2002.
| 12V|green |+ |ignition harness |
| STARTER|BLACK/ red |+ |ignition harness |
| SECOND STARTER|BLACK / YELLOW |+ |ignition harness |
| IGNITION|BLACK/ red |+ |ignition harness |
| ACCESSORY|red |+ |ignition harness |
| SECOND ACCESSORY|WHITE/ blue |+ |ignition harness |
| POWER LOCK|pink *7 |- |pin 37 @ BCM by fuse box |
| POWER UNLOCK|brown *7 |- |pin 44 @ BCM by fuse box |
| LOCK MOTOR|yellow/red | |pin 30 @ BCM by fuse box |
| UNLOCK MOTOR|GREEN / WHITE | |pin 23 @ BCM by fuse box |
| DISARM DEFEAT|GREEN/ red | |pin 31 @ BCM by fuse box |
| PARKING LIGHTS +|RED / blue | |driver kick panel |
| HEADLIGHTS|blu (L), RED / yel (R)|+ |IPDM E/R *1 |
| DOOR TRIGGER|*2 |- |BCM to right of fuse box |
| DOME SUPERVISION|comes on with unlock| | |
| TRUNK/HATCH PIN|PURPLE / white |- |pin 18 @ BCM by fuse box |
| HOOD PIN|yellow/black |- |hood pin switch |
|TRNK/HTCH RELEASE|RED / blk or blu/red |- |pin 76 @ BCM by fuse box |
| FCTRY ALARM ARM|pink/blue *3 |- |driver switch in door |
|FCTRY ALRM DISARM|WHITE/ blue *3 |- |driver switch in door |
| TACHOMETER|WHITE/ green | |ECM behind glove box *4 |
| SPEED SENSE|blue / YELLOW *5 |8 |pin 9 @ instrument cluster |
| BRAKE WIRE|RED / green |+ |brake pedal switch |
| HORN TRIGGER|GREEN / WHITE |- |steering column |
| WIPERS|blu (L), blu/blk (H)|- |wiper motor |
| LF WINDOW UP/DN|blu/red - blu/wht |A |driver window switch |
| RF WINDOW UP/DN|green - yellow *6 |A |driver kick panel |
| LR WINDOW UP/DN|purple - blue |A |driver kick panel |
| RR WINDOW UP/DN|RED / yel - yel/blk |A |driver kick panel |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|YELLOW /GREEN |+ |radio |
| RADIO GROUND| | | |
| RADIO SWITCH|purple |+ |radio |
| RADIO ILLUMINATE|RED / blue |+ |radio |
| POWER ANTENNA|green |+ |radio |
| LF SPEAKER|blu/wht - blu/red | |radio or amp under rear deck|
| RF SPEAKER|wht/blk - blu/blk | |radio or amp under rear deck|
| LR SPEAKER|grn/yel - blk/yel | |radio or amp under rear deck|
| RR SPEAKER|blue - red | |radio or amp under rear deck|
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 The IPDM E/R (Intelligent Power Distribution Module Engine Room) is under the hood behind the passenger side headlight. *2 The LF door trigger is lt. blue in pin 14, RF door is pink/blue in pin 10, and the LR and RR door is RED / black in pin 11. *3 Meter these wires while turning the key in the driver door key cylinder. These wires will also lock and unlock the doors. Unlock requires a double pulse. *4 On the 4 cylinder vehicles it is in pin 36, and on the 6 cylinder it is in pin 34. Can also go to one of the ignition coils and use the wire that is NOT red or black. *5 If vehicle has the midline audio system or BOSE, the vehicle speed sense is also found at the radio, it is pink. *6 If vehicle has auto up/down on the front passenger window switch then must go into the passenger door and use blue for up and GREEN/ black for down. *7 These wires are only available on vehicle with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
