2005 lexus rx 330
civicdownlow
Member - Posts: 26
Posted: September 29, 2004 at 6:16 PM / IP Logged
i did a remote start in a rx 330 and when the customer brought it in he had the autolamps turned off instead of auto so now i have to intrupt the auto light wire but have no info in my tech sheets on it js wonderin if any one can help me out to save me some time
thanx
extreme1
Silver - Posts: 1,070
Posted: September 29, 2004 at 6:21 PM / IP Logged
pulse the drivers door pin with a rearm pulse, autolamps will turn off after they're timeout period
Shaughn Murley
Visions Electronics
Red Deer, Alberta
civicdownlow
Member - Posts: 26
Posted: September 29, 2004 at 6:25 PM / IP Logged
how long is the timed out period it is already pulsing the door pin after shut down
civicdownlow
Member - Posts: 26
Posted: September 29, 2004 at 6:38 PM / IP Logged
got it gotta intrupt the brown wire at the light switch as a passkey and a lock pulse so they dont come on and shut off when u lock it
thanx
snguyen
Silver - Posts: 281
Posted: September 29, 2004 at 9:27 PM / IP Logged
Lexus RX330
2005 lexus rx 330 -- posted image.
 Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS Red Ignition switch +
IGNITION Violet Ignition switch +
IGNITION 2 Green (small gauge) Ignition switch +
ACCESSORY Gray (small gauge) Ignition switch +
STARTER Blue Ignition switch +
STARTER 2 White (small gauge) Ignition switch +
TACH Use an injector
FUEL INJECTOR Opposite from Red At any injector on engine AC
LOCK Brown At keyswitch in driver's door -
UNLOCK Gray (double pulse) At keyswitch in driver's door -
DOORPIN SEE NOTES*
HOODPIN Black At 3-pin plug on hoodlatch assembly -
FACTORY ARM Arms with lock wire
FACTORY DISARM Disarms with unlock wire
BRAKESWITCH Gray/sil. Dots At switch above brake pedal +
PARKLIGHTS Blue On 28-pin plug at front of fusebox +
 Vehicle notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available, contact your supplier to find out. If one is not available to you, please refer to the appropriate security diagram for bypass information.
* Doorpins on this vehicle are independent, Drivers door is Blue , Passenger door is Blue, Right Rear Door is Gray, Left Rear Door is Black, All wires are found at electronic control module attached to bottom of the drivers side fusebox.
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
 ©2002 Autoland All rights reserved
Printed at: 9/29/2004 10:24:45 PM
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
