2004 GMC Yukon Alarm/Remote Start Wiring Info
par3721
Member - Posts: 26
Posted: October 07, 2004 at 1:49 AM / IP Logged
I need wire colors for a 2004 Yukon. This guy wants the Prestige 996 in his Yukon.
Can anyone tell me will the driver presets (seats, mirrors, etc.) still work with the 996 and are they activated by the factory remote or key in the ignition?
This guy would like for the presets to work with the new alarm.
Is there anything i should know before attempting a remote start?
Teken
Gold - Posts: 1,492
Posted: October 07, 2004 at 8:39 AM / IP Logged
GMC Yukon 2004
Remote start / Security / GPS
Wire/Function Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES PASSLOCK 2 SEE NOTES
12 VOLTS Red Ignition switch harness +
IGNITION Pink Ignition switch harness +
IGNITION 2 White* Ignition switch harness +
ACCESSORY Orange Ignition switch harness +
STARTER Yellow* Ignition switch harness +
TACH SEE NOTES**
FUEL INJECTOR Opposite of Pink wire At any injector on engine AC
LOCK SEE NOTES***
DOORPIN Gray/black At courtesy light under dash +
FACTORY ARM SEE NOTES***
BRAKESWITCH White At switch above brake pedal +
PARKLIGHTS Gray/black At light switch harness -
HAND BRAKE Lt.blue At switch on handbrake lever -
HORN Black At steering column -
KEY SENSE Lt.green At steering column -
DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash DATA
Vehicle notes
PLEASE NOTE: This vehicle is equipped with GM's PASSLOCK 2 passive anti-theft system. Please refer to the appropriate diagram before any remote start installation.
* These wire are smaller the other wires from the ignition switch. Test carefully.
** There is a coil for each cylinder, each with a 4-pin plug. Each plug contains a BLACK, BROWN & PINK, as well as a 4th wire which changes color on each coil. This 4th wire can be used as your tach reference, set your remote starter for a 1 cylinder signal.
*** The doorlocks are Class 2 Data on this vehicle and cannot be interfaced directly. Interface modules for both doorlocks and security are available for this vehicle. Contact your supplier for more information.
Note: The information on this sheet is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Wiremagic.com Corporation and/or any associated or unassociated individual or corporation who furnishes this document and/or software assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and Wiremagic.com Corporation and/or any associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly, or in any other way. The information supplied is a guide only.
©2002 Autoland All rights reserved
Printed at: 10/7/2004 9:37:47 AM
Teken
Gold - Posts: 1,492
Posted: October 07, 2004 at 8:40 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - GMC / YUKON / 2004 / Remote Start
12volts red & RED / white   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use Directed module 456G
Notes: If Directed module 456G is not available, refer to DirectFax document 1601. Upper trim level vehicles may have a door lock switch on the right rear panel. If present use white (-) for lock and lt. blue (-) for unlock.
Power Unlock see power lock
Lock Motor gray      driver door module in door
Unlock Motor tan      driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   steering column
Turn Signal(L) green   +   steering column
Turn Signal(R) lt. green   +   steering column
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger see notes   -   see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin pink/black   -   BCM, purple plug, pin A1
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   column or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and RED / white (not used).
Friday, March 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
