wire routing
autobutcher
Member - Posts: 8
Posted: November 08, 2004 at 11:31 AM / IP Logged
what is the best path to feed a all in one dvd player in a 2001 suburban with a power sun roof and rear air  also how do the pillars  remove i have been prying on them but dont want to break them
kidtransam
Copper - Posts: 99
Posted: November 08, 2004 at 7:23 PM / IP Logged
take the door sills off and run the wire under it..and go up to the headliner via the panel between the drivers door and pass door, and you avoid the sunroof mechanism all together.
Or if you just want to run it up the pillars, stay as far to which ever side you decide to run it down. If you are dropping the headliner..use duct tape to hold the wire in place (so when you are working with it, it doesn`t walk on you).
The pillars will have clips on the back of them..you just pull outward on them..unless there are pull handles mounted through them, then you will have to remove those first.
With a torch and a big enough hammer...it WILL friggin fit!!
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
