| 12V|red |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|lt grn (key sense)*5|- |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|lt. blue |+ |drivers kick panel |
| POWER UNLOCK|white |+ |drivers kick panel |
| LOCK MOTOR|gray | |drivers kick panel |
| UNLOCK MOTOR|tan | |drivers kick panel |
| DISARM DEFEAT|tan | |passengers kick panel |
| PARKING LIGHTS +|brown | |headlight switch |
| HEADLIGHTS|blue *4 |- |headlight switch |
| DOOR TRIGGER|*1 |- |*1 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|ORANGE / black |- |*3 |
|TRNK/HTCH RELEASE|gray or black |+ |behind fuse box |
| TACHOMETER|white or orange | |ignition module *2 |
| SPEED SENSE| | | |
| BRAKE WIRE|lt blue |+ |brake pedal switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|brown(L), purple(H) |- |steering column |
| LF WINDOW UP/DN|dk blue - brown |A |switch in center console |
| RF WINDOW UP/DN|lt blue - tan |A |switch in center console |
| LR WINDOW UP/DN|dk green - purple |A |switch in center console |
| RR WINDOW UP/DN|lt green - purple |A |switch in center console |
| SUN RF OPN/CLOSE| | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow |+ |radio |
| RADIO ILLUMINATE|brown |+ |radio |
| LF SPEAKER|tan - gray | |radio |
| RF SPEAKER|lt green - dk green | |radio |
| LR SPEAKER|brown - yellow | |radio |
| RR SPEAKER|dk blue - lt blue | |radio |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. *1 Use gray/black for the drivers door and lt. GREEN/ black for the passenger door(s). The gray/black is located near the diagnostic plug harness under the drivers side of the dash, and the lt. GREEN/ black is located in a black 24 pin plug behind the fuse box in the center console. Use both wires and diode isolate each. *2 Ignition module is on the center front of the motor. Can also find tach at the PCM located behind the battery. *3 On vehicles without power door locks go to the light in the trunk. On vehicles with power door locks can find the wire in a gray 68 pin plug behind the fuse box in the center console. *4 Low beam is high current negative, must use relay. *5 The lt. green key sense wire at the steering column must see a ground during remote start to keep the "SERVICE" light from coming on.
