2002 Pontiac Sunfire, Remote Start/Security Wiring
Welcome Guest :)
dmslinke
Member -
Posted: March 27, 2005 at 11:47 AM / IP Logged
Hey! Does anybody have the wiring diagram/color codeing for a remote start/security system for this car??
boomer_106
Silver -
Posted: March 27, 2005 at 12:19 PM / IP Logged
Here ya go now you can go out and get started. Good luck.
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | N/A | |
Ignition #3: | | N/A | |
Accessory: | | ORANGE | IGNITION SWITCH HARNESS |
Brake Light: | | WHITE | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | PURPLE / White | Coil Pack |
Parking Lights: | | DK. BROWN (+) | AT REAR OF LIGHT SWITCH |
Headlights: | | | |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | | |
Notes: | | * This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. See Note #113 - General Motors PASSLOCK II Bypass Diagram. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED | IGNITION SWITCH HARNESS |
OEM Alarm Disarm: | | DISARMS WHEN VEHICLE IS | STARTED EITHER BY THE KEY OR REMOTELY |
Dome Lights/Superv: | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** |
OEM Horn: | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | LT. BLUE | AT BCM UNDER LEFT SIDE OF DASH ** |
Power Unlock: | | WHITE | AT BCM UNDER LEFT SIDE OF DASH ** |
Trunk Release: | | | |
Alarm Input Wire: | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** |
Notes: | | ** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram. *** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. |
Thursday, April 25, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
