DIRECTWIRE™ WIRING INFORMATION - VOLVO / C70 / 2004 / Remote Start
12volts red (10A) + ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12V.
Starter yellow/white + ignition harness
Second Starter
Ignition GREEN/ YELLOW + ignition harness
Second Ignition blue / YELLOW + ignition harness
Third Ignition
Accessory yellow/purple 5wi ignition harness
Second Accessory
Keysense yellow (required) + ignition harness
Power Lock yellow/gray - keyless module
Notes: The keyless entry module is located above the hood release. It is a black box with 2 green plugs.
Power Unlock gray/red - keyless module
Requires a double pulse for unlock.
Lock Motor yellow 5wi driver kick, door harness
Unlock Motor blue/brown 5wi driver kick, door harness
Parking Lights+ white + headlight switch
Notes: If the vehicle has factory daytime running lights, and you use the white at the switch for parking lights, the headlights will flash as well. The solution is to wire it as a 5 wire system. Also, there are two white wires at the switch. They go to the same pin. Treat them like one wire.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger pink/black - keyless module
To avoid the dome light delay, there are 2 separate door trigger wires at the keyless module. They are: LF WHITE/ black, RF yellow/brown. Both wires are negative trigger and must be diode isolated from each other.
Dome Supervision comes on with unlock
Trunk/Hatch Pin blue/brown - keyless module
Hood Pin yellow/black - keyless module
Trunk/Hatch Release yellow/white - keyless module
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse unlock wire
Tachometer NOT red, black, or yellow ac any ignition coil
Wait to start
Brake Wire yellow + brake pedal switch
Parking Brake
Horn Trigger yellow/red - keyless module
This triggers the alarm horn, the vehicle horns only work with the ignition on.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.
