2004 Kia Amanti Alarm/Remote Start Wiring?
Ren92
Copper - Posts: 56
Posted: June 20, 2005 at 11:31 AM / IP Logged
Does anyone have the wiring colors for an 2004 KIA Amanti?
thepencil
Gold - Posts: 1,526
Posted: June 20, 2005 at 11:39 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - KIA / AMANTI / 2004 / Remote Start
12volts red (30A), pink (30A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition green   +   ignition harness
Second Ignition blue   +   ignition harness
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory N/A
Keysense GREEN/ black   -   ign harn or BCM, 22 pin plug, pin 1
Notes: The BCM (Body Control Module) is to the left of the steering column.
Power Lock use the motor wires
Power Unlock use the motor wires
Lock Motor white   5wi driver door module in door
Unlock Motor yellow   5wi driver door module in door
Parking Lights+ brown (L), orange (R)   +   14 pin plug to right of fuses
Parking Lights- WHITE/ orange   -   BCM, 26 pin plug, pin 10
Hazards blue   -   BCM, 16 pin plug, pin 13
Turn Signal(L) gray   +   BCM, 14 pin plug, pin 9
Turn Signal(R) blue   +   BCM, 14 pin plug, pin 14
Reverse Light gray/orange   +   30 pin plug to right of fuses
Door Trigger green   -   BCM, 16 pin plug, pin 16
Dome Supervision use door trigger wire
Trunk/Hatch Pin blue/black   -   BCM, 22 pin plug, pin 12
Hood Pin yellow   -   BCM, 16 pin plug, pin 6
Trunk/Hatch Release green   -   BCM, 26 pin plug, pin 23
The trunk release is also brown (-) at the release switch in the door.
The fuel door release is green (+) in the driver kick, door harness.
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gray   ac   ignition failure sensor
Notes: The ignition failure sensor is on the driver side of the engine. It has a 4 pin plug, and the tach wire is in pin 2.
Can also go to one of the ignition coils and use the wire that is NOT pink or BLACK/ white.
Wait to start N/A
Brake Wire red or gray   +   brake pedal switch
Parking Brake BROWN / orange   -   BCM, 16 pin plug, pin 8
Horn Trigger GREEN/ orange   -   horn switch
Memory Seat 1 (CAN data bus)
Memory Seat 2 (CAN data bus)
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.2004 Kia Amanti Alarm/Remote Start Wiring? -- posted image.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
