2005 Cobalt Keyless Entry Wiring
Wmleebo
Posted: June 22, 2005 at 1:32 PM / IP Logged
Before I start, your talking to an amature. I have a powerlock/keyless entry kit for my 2005 Cobalt Coupe. The site I bought it from does not have the wiring diagram I need. Can anyone help. Its for a Commando Keyless Entry/Power Lock kit.
thepencil
Gold - Posts: 1,526
Posted: June 22, 2005 at 2:35 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / COBALT / 2005 / Keyless Entry
12volts RED / black (50A)   +   BCM, C3, pin D1
Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Starter yellow (not for remote start)   -   PCM, blue plug, pin 48 or 46
Notes: The PCM (Powertrain Control Module) is on the driver side fender, in front of the underhood fuse block.
There is a white wire and a WHITE/ black wire at the ignition harness that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1610 for remote start interface information.
Ignition yellow   +   ign harn or BCM, C4, pin D3
Power Lock white   -   driver kick or BCM, C1, pin 7
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1500 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray   5wi driver kick or BCM, C3, pin A4
Unlock Motor tan   5wi driver kick or BCM, C3, pin B1
Parking Lights+ brown   +   driver kick or BCM, C3, pin A7
Parking Lights- BROWN / white   -   switch or BCM, C2, pin 5
Hazards white   -   switch or BCM, C2, pin 9
Turn Signal(L) lt. blue (F), yellow (R)   +   BCM, C1, pin 35 and C3, pin A9
Turn Signal(R) dk. blue (F), dk. green (R)   +   BCM, C1, pin 17 and C3, pin A12
Door Trigger gray/black (D), tan/white (P)   -   each kick or BCM, C1, pins 22 and 19
Notes: Use both wires and diode isolate each.
Dome Supervision gray   -   BCM, C3, pin A10
Trunk/Hatch Release tan   -   switch or BCM, C2, pin 10
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passlock
Horn Trigger tan   -   switch or BCM, C2, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock
Part #: 555LW
Notes: Refer to DirectFax document 1610 for remote start interface information.
Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.2005 Cobalt Keyless Entry Wiring -- posted image.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
