2002 Acura RSX Remote Start Wiring
ace2100
Posted: July 06, 2005 at 2:13 PM / IP Logged
Hello,
I am about to install a CarAlarm remote start in A RSX base model. Can anyone please help with daigrams and or photos which can help me out? Thanks!
Moderator - Posts: 12,488
Posted: July 06, 2005 at 2:45 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=719&KW=Acura+RSX
thepencil
Gold - Posts: 1,526
Posted: July 06, 2005 at 4:53 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - ACURA / RSX / 2002 / Remote Start
12volts white (40A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory WHITE/ red   +   ignition harness
Keysense RED / white   -   ign harn or security control unit
Notes: The security control unit is to the left of the steering column.
Power Lock WHITE/ blue   -   driver kick, door harness
Notes: Also found at the multiplex control unit on the back of the fuse box in a 13 pin plug.
Power Unlock WHITE/ green   -   driver kick, door harness
Lock Motor yellow/black   5wi driver kick, door harness
Unlock Motor YELLOW /GREEN   5wi driver kick, door harness
Parking Lights+ RED / black or RED / yellow   +   fuse box
Parking Lights- blue   -   switch or security control unit
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red   +   turn signal switch
Turn Signal(R) GREEN/ YELLOW   +   turn signal switch
Reverse Light green   +   kick panel, harness to rear
Door Trigger green (D), lt. GREEN/ red (P)   -   security control unit
Notes: Use both wires and diode isolate each.
Dome Supervision GREEN/ red   -   driver A pillar
Notes: Also found at the rear of the fuse box in a 12 pin plug.
Trunk/Hatch Pin red   -   security control unit
Hood Pin GREEN/ black   -   security control unit
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm WHITE/ red   -   security control unit
Notes: Meter this wire while turning the key in the driver door key cylinder.
May need to use relay in certain applications.
Factory Alarm Disarm white   -   security control unit
Disarm No Unlock see factory alarm disarm
Tachometer blue   ac   test tachometer connector
Notes: The test tachometer connector is behind the driver side headlight.
Wait to start N/A
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake GREEN/ orange   -   parking brake switch
Horn Trigger orange   -   horn switch
Notes: The horn trigger at the security control unit is green.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: 555I
Alternate Part3 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2002 Acura RSX Remote Start Wiring -- posted image.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
