where to buy resistors?
Jimmy 2 Times
Copper - Posts: 67
Posted: July 21, 2005 at 9:20 AM / IP Logged
i am specifically looking for a 15k resistor.  I am making a timing eliminator for my motorcycle.  I know that a 15k resistor works (becuase i did it on my last bike)  No stores around here sell them (radio shack, and local electrician supply)  Even radio shack.com no longer carries the 15k.  Now i have tried making a 15k resistor (with a bunch of resitors that equal about 15k)  but unfortunately they do not work on the bike.
Where do you guys buy things online, or perhaps maybe some of you a few laying around that i could buy?
thanks for the help
Jimmy
jstruckman
Copper - Posts: 465
Posted: July 21, 2005 at 9:24 AM / IP Logged
partsexpress.com
Jazzy
stevdart
Platinum - Posts: 5,816
Posted: July 21, 2005 at 9:29 AM / IP Logged
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=003-15K
What do you need in watts?  Combining resistors sums the wattage capacity, so you could combine in series or in parallel for more watts.  Use the Parallel and Series Calculators.
DYohn
Moderator - Posts: 10,741
Posted: July 21, 2005 at 9:50 AM / IP Logged
A much better source than Parts Express for electronics supplies is Newark.  They'll have what you need.
Drewt
Copper - Posts: 183
Posted: July 22, 2005 at 12:36 PM / IP Logged
unless your bike is the same make, model, and year as your last one, you may need a different value resistor...
-Drew
Jimmy 2 Times
Copper - Posts: 67
Posted: August 04, 2005 at 11:40 PM / IP Logged
i actually need a 15k ohm 1/2 watt resistor, and parts express no longer carries them
stevdart
Posted: August 05, 2005 at 12:07 AM / IP Logged
If I'm not mistaken, and I don't think I am on this....the wattage value of a resistor is just the value of the wattage where the resistor will maintain its resistance value.  A 5 watt resistor will change in resistance if presented with a higher power.  Which is to say, you can go higher on the wattage value...you can use one that is rated at 10 watts or 20 watts.
haemphyst
Platinum - Posts: 5,054
Posted: August 05, 2005 at 12:32 AM / IP Logged
Three of these in parallel will give you 15.6666666666666666666666666667 kohms (but who's counting where to buy resistors? - Last Post -- posted image. ) at .75 watts. That is enough power capacity, and WELL within tolerance range.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
