12volts | red (30A), red (30A) | + | ignition harness |
Starter | yellow | + | ignition harness |
Second Starter | N/A | | |
Ignition | pink | + | ignition harness |
Second Ignition | N/A | | |
Third Ignition | N/A | | |
Accessory | orange | + | ignition harness |
Second Accessory | brown | + | ignition harness |
Keysense | lt. green | + | ign harn or ETACM, 12 pin plg, pin 6 |
Notes: The ETACM (Electronic Time and Alarm Control Module) is attached to the back of the fuse box, towards the top. |
Power Lock | tan | 5wi | DDM, 10 pin plug, pin 9 |
Notes: The DDM (Driver Door Module) is part of the power window/door lock switch assembly on the driver door panel. |
Power Unlock | gray | 5wi | DDM, 10 pin plug, pin 10 |
Lock Motor | tan | 5wi | DDM, 10 pin plug, pin 9 |
Unlock Motor | gray | 5wi | DDM, 10 pin plug, pin 10 |
Parking Lights+ | purple (L), BROWN / white (R) | + | fuse box, rear 14P plug, pins 9, 10 |
Parking Lights- | lt. blue | - | switch or ETACM, 12 pin plug, pin 5 |
Hazards | green | - | relay or ETACM, 16 pin plug, pin 15 |
Turn Signal(L) | lt. blue | + | fuse box, 18 pin plug, pin 6 |
Turn Signal(R) | blue | + | fuse box, 18 pin plug, pin 14 |
Reverse Light | lt. green | + | DKP or fuse box, rear 14P plg, pin 2 |
Door Trigger | yellow | - | fuse box, 12 pin plug, pin 8 |
Dome Supervision | purple | - | fuse box, 10 pin plug, pin 8 |
Trunk/Hatch Pin | ORANGE / black | - | DKP or fuse box, rear 14P plg, pin 5 |
Hood Pin | blue/black to lt. blue | - | pin sw or ETACM, 12 pin plug, pin 3 |
Trunk/Hatch Release | blue | + | DKP or fuse box, rear 20P plg, pin 2 |
Notes: The fuel filler door release is lt. green (+) in the driver kick, door harness. |
Power Sliding Door | N/A | | |
Factory Alarm Arm | factory remote only | | |
Factory Alarm Disarm | factory remote only | | |
Disarm No Unlock | with ign, acc, and key sense | | |
Tachometer | white | ac | PCM, 26 pin plug, pin 3 |
Notes: The PCM (Powertrain Control Module) is under the center console, to the right of the accelerator pedal.Can also go to any fuel injector and use the wire that is NOT pink or BLACK / YELLOW.Can also go to any ignition coil and use the wire that is NOT pink/black or black. |
Wait to start | N/A | | |
Brake Wire | lt. blue | + | sw or fuse box, rear 14P plg, pin 7 |
Parking Brake | lt. blue | - | parking brake switch |
Horn Trigger | yellow | - | horn switch |
Memory Seat 1 | red | - | switch or DDM, 20 pin plug, pin 20 |
Notes: Memory seat 1 is negative trigger thru a 9200 ohm resistor. MUST use a relay.The DDM (Driver Door Module) is part of the power window/door lock switch assembly on the driver door panel. |
Memory Seat 2 | same as memory seat 1 wire | - | |
Notes: Memory seat 2 is negative trigger thru a 3000 ohm resistor. MUST use a relay. |
Memory Seat 3 | N/A | - | |
