2002 Hyundai Sante Fe Wiring Diagram and info
iskidoo
Silver - Posts: 1,040
Posted: December 08, 2002 at 12:26 PM / IP Logged
Hi I would like to install an aftermarket remote starter that works with my existing keyless entry remote. I have installed one in the past into another vehicle and this unit requires 3 lock pulses (-neg input) within 3 seconds. Does anyone know if this vehicle has a factory alarm or is it just a basic keyless entry system? Also I have a limited wiring diagram but in viewing some of the posted daigs. I noticed there is alot more info on the ones you have been posting. if someone has a more detailed diag I would appreciate it if you could post it. Thanks
Steve G
Moderator - Posts: 12,488
Posted: December 08, 2002 at 5:07 PM / IP Logged
|              12V|red & orange        |+  |ignition harness            |
|          STARTER|blue                |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|green               |+  |ignition harness            |
|       POWER LOCK|yellow              |-  |DKP, white 22 pin plug      |
|     POWER UNLOCK|WHITE/ black         |-  |DKP, white 22 pin plug      |
|       LOCK MOTOR|gray                |   |DKP, white 22 pin plug      |
|     UNLOCK MOTOR|white               |   |DKP, white 22 pin plug      |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|GREEN/ orange        |   |fusebox, 15 pin plug        |
| PARKING LIGHTS -|white               |   |headlight switch            |
|       HEADLIGHTS|gray/black          |-  |headlight switch            |
|     DOOR TRIGGER|yellow              |-  |fusebox, 8 pin plug         |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|BLACK/ orange        |-  |fusebox, 15 pin plug        |
|         HOOD PIN|pink                |-  |ETACS, 12 pin plug *1       |
|  FCTRY ALARM ARM|factory remote only |   |                            |
|FCTRY ALRM DISARM|factory remote only |   |                            |
| DISARM NO UNLOCK|disarms w/rem. start|   |                            |
|       TACHOMETER|WHITE/ black or blue |   |ECM *2                      |
|      SPEED SENSE|brown               |   |data link connector *3      |
|       BRAKE WIRE|GREEN/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|brown               |-  |steering column             |
|           WIPERS|white (L), orange(H)|-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window switch        |
|  RF WINDOW UP/DN|gray - yellow       |A  |driver kick panel           |
|  LR WINDOW UP/DN|red - white         |A  |driver kick panel           |
|  RR WINDOW UP/DN|orange - pink       |A  |driver kick panel           |
| SUN RF OPN/CLOSE|yel/red - yel/red   |A  |sunroof relay in roof       |
|        RADIO 12V|red                 |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow              |+  |radio                       |
| RADIO ILLUMINATE|GREEN/ orange        |+  |radio                       |
|       LF SPEAKER|white - brown       |   |radio                       |
|       RF SPEAKER|yellow - black      |   |radio                       |
|       LR SPEAKER|red - blue          |   |radio                       |
|       RR SPEAKER|green - orange      |   |radio                       |
Notes:
*1 The ETACS module is attached to the back of the fusebox on the bottom. The hood pin is also green at the switch under the hood.  *2 The ECM is under the center console to the right of the gas pedal. On the 2.4L with A/T it is in the 26 pin plug, the 2.4L with M/T it is in the 12 pin plug, and the 2.7L it is in the 40 pin plug.  *3 The data link connector is to the right of the fusebox.
iskidoo
Posted: December 08, 2002 at 5:16 PM / IP Logged
Thank you Jeff. I appreciate that. LOL I kinda was referring to your diagrams earlier. They seem to have lots of useful info that i couldn't get on the Bulldog basic wiring layouts from thier site.
Steve G
Posted: December 08, 2002 at 5:28 PM / IP Logged
Hope this helps you out... if you have any further questions, please post.
Wednesday, April 24, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
