RS3200 '02 Tacoma Aux output
yotaa
Posted: October 24, 2005 at 2:07 PM / IP Logged
Hello,
I have a 2002 Tacoma which includes the VIP RS3200 remote keyless/Alarm installed on it. The key remote has 3 buttons on the face: Lock, Unlock, and Aux.
My question is: If I add a remote car starter to this vehicle, would I be able to utilize the "Aux" button as the trigger for the remote starter? In otherwords, is there an output wire on the RS3200 which coincides with the "Aux" button on the remote so that I could wire that output to an input on the remote starter? If so, does anyone know what wire I am looking for and what the polarity is? I am also assuming that since this was originally designed for a trunk release, that this will be a pulsed output.
Any information would be appreciated.
Thanks,
thepencil
Gold - Posts: 1,526
Posted: October 25, 2005 at 9:52 AM / IP Logged
Why not get a remote starter and alarm unit all together? It's a lot easier to put in a new unit than hurting yourself with the thinking process of combining the two unit to work. It's not a difficult vehicle to do an install on. Lots of room to work with. You will be done with the installation before anyone here can figure how to combine wire together for you. Trust me, it's not worth the aggravation just to save a few bucks.
Be careful whose advice you buy, but be patient with those who supply it.RS3200 '02 Tacoma Aux output -- posted image.
thepencil
Gold - Posts: 1,526
Posted: October 25, 2005 at 9:53 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / TACOMA / 2002 / Remote Start
12volts white & WHITE/ red   +   ignition harness
Starter black   +   ignition harness
Second Starter N/A
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory N/A
Keysense lt. GREEN/ red   -   ignition harness
Power Lock gray   -   front of fuse box, 22 pin plug
Notes: These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Power Unlock purple   -   front of fuse box, 22 pin plug
Lock Motor blue/white   5wi DKP, 12 pin plug in pin 10
Unlock Motor blue   5wi DKP, 12 pin plug in pin 11
Parking Lights+ green   +   back of fuse box, 12 pin plug
Parking Lights- PURPLE / red   -   front of fuse box, 22 pin plug
Hazards same as turn signals
Turn Signal(L) green   +   steering column
Turn Signal(R) GREEN / WHITE   +   steering column
Reverse Light RED / black   +   under driver seat, 13 pin plug
Door Trigger     -   front of fuse box, 22 pin plug
Notes: The driver door trigger is green, the front passenger door trigger is GREEN / WHITE, and the rear door trigger is YELLOW /GREEN. Use all three wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer lt. GREEN/ black   ac   instrument cluster or
Notes: On the 4 cyl it is at the data link connector to the right of the steering column. On the V6 it is at the igniter on the passenger fender, below the air filter box.
Wait to start N/A
Brake Wire GREEN / WHITE   +   brake pedal switch
Parking Brake GREEN / WHITE   -   parking brake switch
Horn Trigger GREEN/ red   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
yotaa
Posted: October 25, 2005 at 11:49 AM / IP Logged
Thanks to The Pencil...
I just purchased the factory alarm unit for this truck. I was hoping to integrate it with the remote starter.
Tuesday, April 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
