2003 Honda S2000 Alarm/Remote Start Wiring
sky8
Posted: December 20, 2005 at 6:03 PM / IP Logged
Anybody has a honda s2000 wiring diagram?  I just bought an 2003 honda s2000 and can't find the vehicle wiring diagram in the 12 volt disk either.  If anybody have the diagram please email me at skyperformance@hotmail.com.  Thank you.
chris354
Silver - Posts: 253
Posted: December 20, 2005 at 6:27 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / S2000 / 2003 / Remote Start
[PRINT THIS PAGE]
12volts white (x2)  +  ignition harness
Starter blue/white  +  L of column, lt blu 24P plug
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition BLACK/ red  +  ignition harness
Third Ignition N/A
Accessory WHITE/ red  +  ignition harness
Second Accessory N/A
Keysense RED / white  -  ignition harness
Power Lock pink/black  5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock YELLOW /GREEN & pink/blue  5wi keyless entry module
Lock Motor pink/black  5wi keyless entry module
Unlock Motor YELLOW /GREEN  5wi keyless entry module
Parking Lights+ RED / black  +  keyless entry module
Parking Lights- blue  -  headlight switch
Hazards same as turn signals
Turn Signal(L) GREEN/ red  +  steering column
Turn Signal(R) GREEN/ YELLOW  +  steering column
Reverse Light GREEN/ black  +  driver kick, gry 14 pin plug
Door Trigger BLACK/ white  -  keyless entry module
Dome Supervision use door trigger
Trunk/Hatch Pin blue/black  -  driver kick, gry 14 pin plug
Hood Pin yellow/red  -  security control module
Notes: The security control module is located under the driver side seat.
Trunk/Hatch Release BLACK / YELLOW  +  keyless entry module
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm white  -  keyless entry module
Disarm No Unlock blue  -  security control module
Tachometer blue  ac  tach test connector
Notes: The tach test connector is a 2 pin black plug behind the auxiliary underhood fuse box on the driver side of the engine compartment.
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN / WHITE  -  L of column, lt blu 24P plug
Horn Trigger orange  -  keyless entry module
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2003 Honda S2000 Alarm/Remote Start Wiring -- posted image.
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
