| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|RED / black (10A) *7|+ |ignition harness |
| STARTER|yellow/white |+ |ignition harness |
| IGNITION|blue/red |+ |ignition harness |
| SECOND IGNITION|yellow (key sense) |+ |ignition harness |
| ACCESSORY|purple |+ |ignition harness |
| POWER LOCK|PURPLE / white |- |drivers door module *2 |
| POWER UNLOCK|blue/white |- |drivers door module *2 |
| LOCK MOTOR|yellow | |drivers door module |
| UNLOCK MOTOR|gray | |drivers door module |
| DISARM DEFEAT|gray | |drivers rear door harness |
| PARKING LIGHTS +|white | |fuse box |
| HEADLIGHTS| | | |
| DOOR TRIGGER|pink |- |each door harness *4 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|BROWN / orange |- |trunk pin switch *5 |
| HOOD PIN|yellow |- |hood pin switch |
|TRNK/HTCH RELEASE|gray/white |5wi|in trunk *6 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|*3 | | |
| TACHOMETER|*1 | |ignition coil |
| BRAKE WIRE|yellow |+ |brake switch |
| HORN TRIGGER|yellow |- |central electronic module |
| WIPERS|blue and yellow |+ |wiper motor |
| LF WINDOW UP/DN|RED / black - purple |A |LF window switch |
| RF WINDOW UP/DN|RED / black - purple |A |RF window switch |
| LR WINDOW UP/DN|RED / black - purple |A |LR window switch |
| RR WINDOW UP/DN|RED / black - purple |A |RR window switch |
| RADIO 12V|red |+ |radio |
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|purple |+ |radio |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA| | | |
| LF SPEAKER|gry/red - gray | |radio |
| RF SPEAKER|gry/red - gray | |radio |
| LR SPEAKER|gry/wht - gray | |radio |
| RR SPEAKER|gry/wht - gray | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. *1 Use any of the following; blue, brown, yellow, pink, purple, or gray. *2 These are the drivers door key cylinder wires, meter by turning the key in the door. Unlock requires a double pulse. *3 A single pulse on the unlock wire will disarm the factory alarm without unlocking the doors. *4 There is pink wire for each of the 4 doors. Use all of them and diode isolate. All four wires can also be found at the central electronic module under the driver side dash in three separate plugs. *5 Also found pink at the central electronic module. *6 In a white plug behind the driver side taillight. *7 This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
