12volts | lt. GREEN/ purple (20A) | + | ignition harness |
Starter | dk. green | + | ignition harness |
Second Starter | N/A | | |
Ignition | WHITE/ yellow | + | ignition harness |
Second Ignition | N/A | | |
Third Ignition | N/A | | |
Accessory | BLACK/ pink | + | ignition harness |
Second Accessory | N/A | | |
Keysense | lt. GREEN/ purple | + | ignition harness |
Power Lock | WHITE/ purple or ORANGE / black | - | SJB, blk 26 pin plug, pin 3 or 8 |
Notes: The SJB (Smart Junction Box) is in the passenger kick panel.These wire are also found in each kick, in the door harness. The first wire listed is the driver switch wire and the second is the passenger switch wire. |
Power Unlock | dk. blue/lt. grn or yellow/red | - | SJB, blk 26 pin plug, pin 1 or 5 |
Lock Motor | RED / orange | 5wi | DKP or SJB, blk 5 pin plug, pin 3 |
Notes: The SJB (Smart Junction Box) is in the passenger kick panel. |
Unlock Motor | yellow | 5wi | DKP or SJB, blk 5 pin plug, pin 1 |
Parking Lights+ | SJB ctrls each light separate | | |
Parking Lights- | BLACK/ lt. green | - | sw. or SJB, blu 52 pin plug, pin 31 |
Hazards | RED / white | - | sw. or SJB, blu 52 pin plug, pin 24 |
Turn Signal(L) | SJB ctrls each light separate | | |
Turn Signal(R) | SJB ctrls each light separate | | |
Reverse Light | WHITE/ yellow | + | PKP or SJB, gry 52 pin plug, pin 13 |
Door Trigger | use dome supervision wire | | |
Notes: The individual door trigger wires are Normally Close type. They rest at ground with the door closed and go to an open circuit with the door open. The driver door is lt. GREEN/ black at the SJB, black 26 pin plug, pin 2. The passenger door is yellow/lt. green at the SJB, black 26 pin plug, pin 6.The SJB (Smart Junction Box) is in the passenger kick panel. |
Dome Supervision | lt. GREEN/ YELLOW | - | SJB, gry 26 pin plug, pin 25 |
Notes: The SJB (Smart Junction Box) is in the passenger kick panel.Also found in the passenger side A pillar. |
Trunk/Hatch Pin | WHITE/ yellow | + | lt. or SJB, blk 26 pin plug, pin 15 |
Hood Pin | PURPLE / orange | - | pin or SJB, blk 52 pin plug, pin 15 |
Notes: The hood pin wire rests at ground and goes to an open circuit with the hood open.The SJB (Smart Junction Box) is in the passenger kick panel. |
Trunk/Hatch Release | WHITE/ purple | - | PKP or SJB, blk 52 pin plug, pin 13 |
Notes: The SJB (Smart Junction Box) is in the passenger kick panel.The trunk release motor wire is pink/orange (+) in the passenger kick, harness to rear. |
Power Sliding Door | N/A | | |
Factory Alarm Arm | lt. blue/pink | - | DKP or SJB, blk 26 pin plug, pin 18 |
Factory Alarm Disarm | lt. blue/black | - | DKP or SJB, blk 26 pin plug, pin 9 |
Disarm No Unlock | see factory alarm disarm | | |
Tachometer | NOT red | ac | any ignition coil or fuel injector |
Wait to start | N/A | | |
Brake Wire | lt. green | + | sw. or SJB, gry 36 pin plug, pin 16 |
Parking Brake | RED / yellow | - | sw. or SJB, blk 52 pin plug, pin 50 |
Horn Trigger | dk. blue | - | sw. or SJB, blu 52 pin plug, pin 39 |
Memory Seat 1 | N/A | | |
Memory Seat 2 | N/A | | |
Memory Seat 3 | N/A | | |
