2006 Chevy Optra/Suzuki Forenza Alarm/RS Wiring
desh187
Copper - Posts: 310
Posted: September 28, 2006 at 11:41 PM / IP Logged
Does anyone have wiring schematics for a 2006 Chevy Optra?My understanding is that this vehicle is a Canadian import from GM korea(which used to be Daewoo).I have to install an alarm/autostart.
Thanks in advance.
caraudio904
Copper - Posts: 115
Posted: September 29, 2006 at 12:50 AM / IP Logged
I can't find it maybe someone else. I would love to get my hands on that though. Never touched one
Southern Stylez
Jacksonville, FL 32218
desh187
Copper - Posts: 310
Posted: October 03, 2006 at 8:50 PM / IP Logged
Just to let Canadian installers know that the Chevy Optra is known as Suzuki Forenza in the US.
shaggy12volt
Copper - Posts: 164
Posted: October 03, 2006 at 9:11 PM / IP Logged
here is the info for the Forenza if this work let me know so i can update my data base just test the wires first dont reliy on it
WIRING INFORMATION - SUZUKI / FORENZA / 2006 / Remote Start
[PRINT THIS PAGE]
12volts red (30A), red (30A) + ignition harness
Starter dk. blue or yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green to lt. GREEN/ red + ignition harness
Notes: Also found at the remote keyless/anti theft module under the floor console, if equipped.
Power Lock lt. GREEN / WHITE - driver kick, door harness
Power Unlock white to yellow - driver kick, door harness
Lock Motor gray/white to gray 5wi driver kick, door harness
Unlock Motor purple to PURPLE / white 5wi driver kick, door harness
Parking Lights+ PURPLE / wht (L), BROWN / wht (R) + driver kick, harness to rear
Parking Lights- white - headlight switch
Hazards same as turn signal wires
Turn Signal(L) lt. blue + turn signal switch
Turn Signal(R) dk. blue + turn signal switch
Reverse Light lt. green + driver kick, harness to rear
Door Trigger purple - driver kick, harness to rear
Dome Supervision use door trigger wire
Trunk/Hatch Pin pink/black - light in trunk
Hood Pin pink/black to pink/dk. blue + hood pin switch
Trunk/Hatch Release brown + driver kick, door harness
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm dk. blue to lt. green - driver kick, door harness
Disarm No Unlock see factory alarm disarm
Tachometer gray ac ECM, red plug, pin 41
Notes: The ECM (Engine Control Module) is on the center of the firewall under the hood. The tachometer wire is also found at the instrument cluster.
Wait to start N/A
Brake Wire lt. blue + brake pedal switch
Parking Brake PURPLE / white - parking brake switch or DRL mod
Notes: The DRL (Daytime Running Lights) module is under the driver side dash.
Horn Trigger black - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2006 Chevy Optra/Suzuki Forenza Alarm/RS Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Thursday, April 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
