2006 Jeep Liberty Alarm Wiring
Welcome Guest :)
dangerousdarren
Member -
Posted: October 14, 2006 at 10:15 AM / IP Logged
I need a wiring diagram for this please.
Darren
KarTuneMan
Platinum -
Posted: October 14, 2006 at 5:23 PM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | Red | Ignition switch harness | + |
IGNITION | Pink/green | Ignition switch harness | + |
ACCESSORY | Pink / YELLOW | Ignition switch harness | + |
| | There are 2 Pink / YELLOWs, one for the radio and one for heater, test carefully. |
STARTER | Lt.blue/red | Ignition switch harness | + |
KEY SENSE | Violet/tan | Ignition harness | - |
TACH SIGNAL | SEE NOTES | | |
| | There is an uncommon wire at each coil which can be used for tach. |
FUEL INJECTOR | Opposite from ORANGE / dk.green | At any injector on engine | AC |
LOCK | Tan/blue (1500-ohms) | In large harness to left of brake pedal | - |
| | This is a 1-wire system with resistors. The keyless entry is built in to the ignition key and works even while the vehicle is running. Unless you are installing after-market security, no connection to the doorlock wire is required. |
UNLOCK | Tan/blue (470-ohms) | In large harness to left of brake pedal | - |
DOORPIN | SEE NOTES | | |
| | Violet (left front), Violet/white (right front), Violet/gray (left rear) & Violet / YELLOW (right rear) all 4 wires are (-) and found in the large white plug above the driver's kickpanel. |
TRUNK PIN | Tan/black or Violet/orange | In large White plug above driver's kickpanel | - |
TRUNK RELEASE | Blue/green or lt.GREEN / WHITE | In large White plug above driver's kickpanel | + |
FACTORY ARM | SEE NOTES | | |
| | To arm the alarm, pulse the TAN driver's doorpin at the same time as the lock wire. |
FACTORY DISARM | Disarms with unlock | | |
BRAKESWITCH | WHITE/ tan | At switch above brake pedal | + |
PARKLIGHTS | Pink/red (900-ohms) | At steering column | - |
HAND BRAKE | GREEN / WHITE | At switch on handbrake lever | - |
HORN | GREEN/ violet | At steering column | - |
VSS WIRE | GREEN/ YELLOW | Behind fusebox (under driver side dash) | AC |
DATABUS INTERFACE | Pin-2(top row from left) | Diagnostic plug below dash | DATA |
dangerousdarren
Member -
Posted: October 16, 2006 at 8:54 PM / IP Logged
Thanks. I figured out it is the same as the 04, but thanks anyway.
Darren
Thursday, April 25, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
