2006 Nissan Titan KCab Alarm/Remote Start Wiring
Welcome Guest :)
spokes18
Member -
Posted: November 02, 2006 at 3:06 PM / IP Logged
I need a schematic for a 2006 Nissan Titan. does any one have something
Thanks Spokes18
KarTuneMan
Platinum -
Posted: November 02, 2006 at 3:14 PM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | Green | Ignition Harness | + |
IGNITION | BLACK/ Red | Ignition Harness | + |
ACCESSORY | Red | Ignition Harness | + |
STARTER | Brown | Ignition Harness | + |
STARTER 2 | Lt.Green | Ignition Harness | + |
KEY SENSE | RED / blue | Ignition switch harness | + |
TACH SIGNAL | SEE NOTES | | AC |
| | This vehicle has independent coils, there are three wires per coil, WHITE/ Blue, Black and the third is the tach signal wire. |
FUEL INJECTOR | Opposite of White | At any injector on engine | AC |
LOCK | Blue | At switch inside driver's door | - |
| | You must run wires into the doors to connect to these wires. The first pulse on the RED will disarm and a double pulse will unlock the doors. |
UNLOCK | Red | At switch inside driver's door | - |
DOORPIN | SEE NOTES | | |
| | Driver's door is LT.BLUE, front passenger door is RED / BLUE. The left rear door is RED / YELLOW and the right rear door is RED / WHITE. All 4 wires are (-) and found at the BCM on the right side of the steering column. |
R.A.P. SHUT DOWN | Lt.Blue | SEE NOTES | - |
| | This vehicle is equipped with automatic headlights that will stay on after a remote shutdown.you must pulse the drivers doorpin wire to shut the lights off. Drivers doorpin is Lt.Blue at BCM on right side of steering column. |
FACTORY ARM | Arms with lock wire | | |
FACTORY DISARM | Disarms with unlock wire | | |
BRAKESWITCH | RED / Green | At brake switch | + |
PARKLIGHTS | RED / Blue | At dimmer switch | + |
HAND BRAKE | Green | At switch on handbrake lever | - |
HORN | RED / White | At steering column harness | - |
VSS WIRE | WHITE/ red | Behind instrument panel | AC |
Available Notes
| PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. Please refer to the appropriate security diagram before any remote start installation. |
| N/A |
| N/A |
gcorrea
Silver -
Posted: November 02, 2006 at 10:05 PM / IP Logged
most xe models dont have a transponder key.
gcorrea
nipplz
Member -
Posted: November 02, 2006 at 10:46 PM / IP Logged
i have only seen 1 nissan since 2004 without a transponder
gcorrea
Silver -
Posted: November 02, 2006 at 11:00 PM / IP Logged
xes are the base models.
gcorrea
Thursday, April 25, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
