WinISD, ported designed box
astro88
Copper - Posts: 195
Posted: November 12, 2006 at 7:40 PM / IP Logged
Ive calculated my parameters and came up with a plan for a ported box but all i need to know is,
Is the port displacement calculated by the program or do i have to do that myself?
Like do i just build the box to the size i came up with or do i add port displacement to the total?    .....Sorry first ported design(i wanna do it right)
TIA
aznboi3644
Gold - Posts: 2,600
Posted: November 13, 2006 at 4:34 PM / IP Logged
port displacement is not acounted for...you must add it into the total volume
astro88
Copper - Posts: 195
Posted: November 13, 2006 at 8:42 PM / IP Logged
how do i figure out port displacement?
stevdart
Platinum - Posts: 5,816
Posted: November 13, 2006 at 8:49 PM / IP Logged
If it's a cylindrical port, use the calculator found over to the left side of this page under "woofer calculators", tube/cylinder volume calculator.  Measure the total width of the outside dimensions of the port and enter that as diameter, then enter 0 as thickness.  This keeps you from having to measure a thin walled port thickness.  Decide on what you will use for a port and get the necessary measurement.
If it's a slot port, decide how you are going to incorporate it into the box.  Anything you use to build the port that is in addition to the box, as well as the air volume inside the port, is figured as port displacement.
astro88
Copper - Posts: 195
Posted: November 13, 2006 at 9:12 PM / IP Logged
thanx much!
aznboi3644
Gold - Posts: 2,600
Posted: November 13, 2006 at 11:26 PM / IP Logged
Um...just use a simple math formula for Volume....basically base times height
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
