2005 dodge stratus
jmg420
Posted: November 29, 2006 at 6:22 AM / IP Logged
i am trying to find the audio wiring diagrams for my car. i am having problems with the front speakers not working and would like to get my new cd deck up and running.
thepencil
Gold - Posts: 1,526
Posted: November 30, 2006 at 1:03 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / STRATUS SEDAN / 2005 / Audio
[PRINT THIS PAGE]
Radio 12v pink   +   radio harness
Radio Ground black   -   radio harness
Radio Ignition RED / white   +   radio harness
Radio Illumination ORANGE / brown (dimmer)   +   radio harness
Factory Amp Turn-on same as power antenna wire
Notes: If equipped, the amplifier is under the passenger seat.
Power Antenna dk. GREEN/ red   +   radio harness
LF Speaker +/- dk. green - BROWN / red   +,- radio harness
RF Speaker +/- purple - dk. blue/red   +,- radio harness
LR Speaker +/- BROWN / yellow - BROWN / lt. blue   +,- radio harness
RR Speaker +/- dk. blue/white - dk. blue/org   +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 457CW
Alternate Part1 #: 456LW
Notes:
Smart Starter Kill Relays: Relay Type:
Starter Relay Location:
Engine compartment fusebox, Driver side
Part #: 6403A
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.2005 dodge stratus -- posted image.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
