wiring diagram for 06 Acura MDX
tbo1
Member - Posts: 9
Posted: December 18, 2006 at 1:54 PM / IP Logged
Hello everyone, I need a wiring diagram for a 2006 Acura MDX. Thank you in advance.
tbo
Twelvoltz
Platinum - Posts: 2,384
Posted: December 18, 2006 at 2:45 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - ACURA / MDX / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      white (50A)       +       ignition harness
Starter      BLACK/ white       +       ignition harness
Second Starter      N/A
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow       +       ignition harness
Second Accessory      WHITE/ black       +       ignition harness
Keysense      blue/white       -       ignition harness
Power Lock      BLACK/ orange       -       pass fuse box, 20 pin plug, pin 6
Notes: Meter this wire while using the power door lock switch on the passenger door.
Power Unlock      blue/orange       -       pass fuse box, 20 pin plug, pin 5
Lock Motor      WHITE/ red       5wi      driver fuse box, 18 pin plug, pin 4
Unlock Motor      yellow       5wi      driver fuse box, 18 pin plug, pin 1
Parking Lights+      RED / black       +       driver fuse box, 20 pin plug, pin 18
Parking Lights-      RED / yellow       -       headlight switch
Hazards      same as turn signal wires
Turn Signal(L)      GREEN/ blue       +       turn signal switch
Turn Signal(R)      GREEN/ YELLOW       +       turn signal switch
Reverse Light      GREEN/ black       +       driver fuse box, 10 pin plug, pin 6
Door Trigger      BLACK/ white       -       pass fusebox, rear 18 pin plg, pin 8
Notes: Can also use individual door trigger wires. The LF door is GREEN/ orange at the driver fuse box, 10 pin plug, pin 3. The RF door is green at the passenger fuse box, 20 pin plug, pin 16. The LR door is lt. GREEN/ black at the driver fuse box, 10 pin plug, pin 10. The RR door is GREEN / WHITE at the passenger fuse box, 20 pin plug, pin 14. Use all four wires and diode isolate each.
Dome Supervision      GREEN / WHITE       -       driver footwell light
Trunk/Hatch Pin      blue/black to orange       -       dri mux ctrl unit, green plug, pin 8
Notes: The driver multiplex control unit is attached to the driver fuse box in the driver kick panel. It has a single green plug facing the firewall.
Hood Pin      yellow/red to yellow       -       dri mux ctrl unit, green plug, pin 6
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      blue/white       -       door mux ctrl, lt. blue plug, pin 6
Notes: Meter this wire while turning the key in the driver door key cylinder.
The door multiplex control unit is part of the power window master switch in the driver door.
Factory Alarm Disarm      BLACK/ red to blue       -       door mux ctrl, lt. blue plug, pin 16
Disarm No Unlock      see factory alarm disarm
Tachometer      GREEN/ blue       ac       pass fuse box, 20 pin plug, pin 10
Notes: Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Can also go to any fuel injector and use the wire that is NOT yellow/black.
Wait to start      N/A
Brake Wire      WHITE/ black       +       brake pedal switch
Parking Brake      GREEN/ red       -       dri mux ctrl unit, green plg, pin 15
Horn Trigger      brown to lt. GREEN/ blue       -       horn switch
Memory Seat 1      blue/green       -       pwr seat ctrl, 20 pin plug, pin 8
Notes: The driver power seat control unit is under the driver seat.
Memory Seat 2      blue / YELLOW       -       pwr seat ctrl, 20 pin plug, pin 19
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556HW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100F or 1100X, a software change to 1100HKD is needed. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / black, data wire is red and ignition wire is GREEN / WHITE.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
tbo1
Member - Posts: 9
Posted: December 18, 2006 at 4:16 PM / IP Logged
Thank you very much Twelvoltz. Hope I can return the good deed sometimes.
tbo
Saturday, April 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
