1996 mercury villager wire diagrame
big j.v.
Posted: February 18, 2007 at 10:56 PM / IP Logged
I want to install a remot start/keyless entry/alarm in my minivan but I cant find the diagrame that I need to know what wriers to hook it up to. Can someone help me out here?
Experiance is learning form your mistakes(and not making them again!!!!)
Twelvoltz
Platinum - Posts: 2,384
Posted: February 18, 2007 at 11:01 PM / IP Logged
DEI Lists:
DIRECTWIRE™ WIRING INFORMATION - MERCURY / VILLAGER / 1996 / Remote Start
[PRINT THIS PAGE]
12volts      WHITE/ purple       +       ignition harness
Starter      red       +       ignition harness
Second Starter      WHITE/ blue       +       ignition harness
Ignition      brown       +       ignition harness
Second Ignition      RED / green       +       ignition harness
Third Ignition
Accessory      WHITE/ green       +       ignition harness
Second Accessory
Keysense
Power Lock      GREEN / WHITE       -       left kick or console
Power Unlock      GREEN/ orange       -       left kick or console
Lock Motor      GREEN/ YELLOW             drivers kick panel
Unlock Motor      WHITE/ green             drivers kick panel
Parking Lights+      pnk/blu or pnk/wht             left kick
Parking Lights-      ORANGE / black             headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / white       -       left kick or
Notes: Grounded at rest thru dash ind. - use diode to isolate. Also look for RED / black in unplugged two pin connector in center console. Should also cover rear hatch. There is also a blue (-) wire in the center console that catches all doors on keyless models.
Dome Supervision
Trunk/Hatch Pin      lt BROWN / white       -       left kick
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      red       -       drivers kick or SECU
Notes: The Smart Entrance Control Unit is behind the center console.
Factory Alarm Disarm      RED / black       -       drivers kick or SECU
Disarm No Unlock
Tachometer      green       ac      ign. module on engine
Wait to start
Brake Wire      yellow/black       +       brake pedal switch
Parking Brake
Horn Trigger      black       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
big j.v.
Posted: February 19, 2007 at 7:23 PM / IP Logged
Do the second igniton and second starter wires need to be connected to make a remote starting system work on ths van?
jim hunter
Silver - Posts: 351
Posted: February 19, 2007 at 8:59 PM / IP Logged
yes they do, its essentially a nissan van and all nissans have a 2nd starter wire ( some cold start module or so ive been told)
and without 2nd ignition powered up car will not start and may throw trouble codes
so you will have to add a relay fro the 2nd starter wire, the 2nd igniton is onboard in the module
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
