Alarm/Remote Start Wiring, 07 Toyota Corolla
davissaini
Posted: July 23, 2007 at 3:46 PM / IP Logged
Does anybody know the wiring diagram for a 2007 Toyota Corolla LE for installing a security/remote starter. Help would be appreciated.
mikvot
Gold - Posts: 1,043
Posted: August 05, 2007 at 8:32 PM / IP Logged
12volts
  white (25A), black (15A)
  ignition harness
Starter  red   +   ignition harness
Second Starter  N/A
Ignition  BLACK/ white   +   ignition harness
Second Ignition  BLACK / YELLOW   +   ignition harness
Third Ignition  N/A
Accessory  blue/red   +   ignition harness
Second Accessory  N/A
Keysense  blue/black   -   ignition harness
Power Lock  green   -   driver kick, 10 pin plug
Power Unlock  blue / YELLOW (double pulse)   -   driver kick, 10 pin plug
Lock Motor  blue   5wi  driver kick, blue 12 pin plug
Unlock Motor  red   5wi  driver kick, blue 12 pin plug
Parking Lights+  green   +   driver kick, harness to rear
Parking Lights-  GREEN / WHITE   -   headlight switch
Hazards  yellow/black   -   flasher relay left of fuse box
Turn Signal(L)  GREEN/ black   +   flasher relay left of fuse box
Turn Signal(R)  GREEN/ YELLOW   +   flasher relay left of fuse box
Reverse Light  RED / black   +   front of fuse box, 10 pin plug
Door Trigger  red   -   front of fuse box, 10 pin plug
Dome Supervision  use door trigger wire
Trunk/Hatch Pin  RED / white   -   light in trunk
Hood Pin  N/A
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  arms with lock
Factory Alarm Disarm  disarms with unlock
Disarm No Unlock  use key sense wire
Tachometer  black   ac   ECM, far right plug, pin 5
Wait to start  N/A
Brake Wire  GREEN / WHITE   +   brake pedal switch
Parking Brake  RED / black   -   parking brake switch
Horn Trigger  GREEN/ YELLOW   -   horn switch
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
