panasonic wiring diagrams
iS220
Posted: May 26, 2002 at 2:33 PM / IP Logged
Hey guys, i really need help.  I have a 97 accord sedan and i am trying to install a panasonic DP22 cd reciever in there.  I don't have the wiring diagram and i need it.  i try to match up the colors to the car but it won't turn on, its really gettin me upset.  There are two yellow wires, and two black wires.  I try different combos but it still doesn't work.  If anyone can tell me where i can find panasonic wiring digrams i would deeply appreciate it.  Thanks.
Moderator - Posts: 12,602
Posted: May 26, 2002 at 2:54 PM / IP Logged
If you've been trying to attach a (-) wire to a positive input , the CD player may not be working even if you have the right wires ! Most if not all the Panasonic players have the same plug connections .
HotRod53F100
Copper - Posts: 86
Posted: May 26, 2002 at 8:13 PM / IP Logged
I don't want to be the bearer of bad news BUT..be very careful in doing your wiring. The colors on the car rarely match those of the aftermarket radio. Here's the scarry part..if your radio was grounded and you put 12V to an audio output, you could very easily wipe out the outputs. I would think that Panasonic would provide tech support and give you another diagram. I know that years ago before the days of the internet, you could just call and get wiring and schematics it sent to you. Good Luck!
HotRod
install_tech
Member - Posts: 38
Posted: May 27, 2002 at 10:12 AM / IP Logged
This should help you out:
http://www.panasonic.com/consumer_electronics/support/default.asp
Good Luck!
install_tech
Sunday, February 26, 2017 • Copyright © 1999-2017 the12volt.com Donate to the12volt.com Advertising Top of Page
