2007 Sebring Sedan, Remote Start/Alarm Wiring
1000toni
Member - Posts: 14
Posted: August 23, 2007 at 5:15 PM / IP Logged
Anyone have the wiring color diagrams for a 2007 sebring , need to install a remote starter & alarm.
Thank you!
ceasar326
Copper - Posts: 239
Posted: August 23, 2007 at 5:37 PM / IP Logged
CHRYSLER / SEBRING SEDAN / 2007 / Remote Start
12volt RED / tan (10A)  +  ignition harness
Starter yel/pur (not for remote start) +  driver fender
Notes: On the 4 cylinder models, it is in a 20 pin plug, pin 12.
On the 6 cylinder models, it is in a 14 pin plug, pin 6.
Also found at the TIPM, lt. gray 8 pin plug, pin 8.
The TIPM (Totally Integrated Power Module) is under the hood on the driver fender.
Second Starter PURPLE / brown  -  ignition harness
Notes: Starter is negative trigger thru a 180 ohm resistor. See DirectFax document 1084 for wiring information.
Ignition pink  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter wire
Notes: Accessory is negative trigger thru a 610 ohm resistor. See DirectFax document 1084 for wiring information.
Second Accessory N/A
Keysense same as second starter wire
Notes: Key sense is negative trigger thru a 8500 ohm resistor.
Power Lock lt. grn/pur or lt. grn/dk. grn -  DKP or cluster, brown plug, pin 18
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor tan/dk. blue  5wi DKP or cluster, bk 10 pin plg, pin 9
Unlock Motor tan/dk. green  5wi DKP or cluster, bk 10 pin plg, pin 5
Parking Lights+ WHITE/ purple  +  driver kick, harness to rear
Parking Lights- (LIN data bus)
Hazards (LIN data bus)
Turn Signal(L) wht/lt. grn(F), wht/dk. grn(R) +  light (F); dr kick, harn to rear (R)
Turn Signal(R) WHITE/ tan (F), WHITE/ yel (R)  +  light (F); dr kick, harn to rear (R)
Reverse Light WHITE/ lt. green  +  driver kick, harness to rear
Door Trigger see notes  -  each kick or cluster, brown plug
Notes: The LF door is purple in pin 3. The RF door is PURPLE / white in pin 11. The LR door is PURPLE / gray in pin 5. The RR door is purple / YELLOW in pin 6. Use all four wires and diode isolate each.
Dome Supervision yellow/white  +  DKP or cluster, brown plug, pin 4
Notes: Also found in the passenger kick or in the passenger side A pillar.
Trunk/Hatch Pin PURPLE / orange  -  DKP or cluster, brown plug, pin 13
Hood Pin PURPLE / lt. blue  -  hood pin switch under hood
Trunk/Hatch Release lt. GREEN / WHITE  -  sw or cluster, bk 20 pin plg, pin 13
Notes: The trunk release motor wire is tan / YELLOW (+) in the driver kick or at the cluster, black 10 pin plug, pin 4.
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ign, keysense, Sentry Key
Tachometer NOT BROWN / dk. blu or BROWN / yel ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire dk. GREEN / WHITE  +  switch or cluster, brown plug, pin 8
Parking Brake dk. GREEN / WHITE  -  switch or cluster, brown plug, pin 7
Horn Trigger dk. GREEN/ purple  -  sw or cluster, bk 20 pin plg, pin 10
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2007 Sebring Sedan, Remote Start/Alarm Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: PKU-CH2X
Alternate Part1 #: 556CW
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
No
Type:
Data Bus
Part #: XK03
Alternate Part1 #: 456LW
Notes:
Combo Interface
Required:
No
Type:
Data Bus
Part #: XK532
Alternate Part1 #: IOM-Chrysler-7
Notes: When using the combo module it is not necessary to use doc 1084. That part takes care of 2nd starter and accessory, locks, and bypass.
1000toni
Member - Posts: 14
Posted: August 24, 2007 at 12:59 PM / IP Logged
ok tanks.
Thursday, March 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
