06 scion xa alarm/remote start wiring
Welcome Guest :)
cyclotron_bUrst
Member -
Posted: October 08, 2007 at 7:43 AM / IP Logged
I am in need of the Wiring Diagram for my 06 Scion xA so I can get my remote start and alarm working since they changed some wire colors and locations between the 04 and 06.
KarTuneMan
Platinum -
Posted: October 08, 2007 at 12:29 PM / IP Logged
12 VOLTS | WHITE/ blue | Ignition switch harness | + |
IGNITION | BLACK/ red | Ignition switch harness | + |
ACCESSORY | WHITE/ blue | Ignition switch harness | + |
STARTER | Black or WHITE/ black | Ignition switch harness | + |
KEY SENSE | Yellow | Ignition switch harness | - |
TACH SIGNAL | Black | In 18-pin plug behind fusebox under dash | AC |
LOCK | BROWN / yellow | On plug in driver's kickpanel | - |
UNLOCK | Blue / YELLOW | On plug in driver's kickpanel | - |
DRIVER LOCK MOTOR | Blue/white | In driver's kickpanel | REV POL |
DRIVER UNLOCK MOTOR | Blue/black | In driver's kickpanel | REV POL |
DOORPIN | RED / white | In driver's kickpanel or at fusebox | - |
TRUNK PIN | Common with doors | | |
BRAKESWITCH | Dk.GREEN / WHITE | At switch above brake pedal | + |
PARKLIGHTS | Green | Near top of fusebox under dash | + |
HAND BRAKE | Yellow/red | At top of fusebox | - |
HORN | WHITE/ red | At steering column | - |
DRIVER WINDOW UP | Red | At switch in driver's door | REV POL |
DRIVER WINDOW DOWN | Green | At switch in driver's door | REV POL |
PASSENGER WINDOW UP | Blue/white | In driver's kickpanel | REV POL |
PASSENGER WINDOW DOWN | Blue / YELLOW | In driver's kickpanel | REV POL |
LEFT REAR WINDOW UP | RED / yellow | In driver's kickpanel | REV POL |
LEFT REAR WINDOW DOWN | GREEN/ YELLOW | In driver's kickpanel | REV POL |
RIGHT REAR WINDOW UP | RED / black | In driver's kickpanel | REV POL |
RIGHT REAR WINDOW DOWN | GREEN/ black | In driver's kickpanel | REV POL |
REVERSE LIGHTS | RED / white | At top of fusebox | + |
VSS WIRE | PURPLE / white | At back of fusebox | AC |
cyclotron_bUrst
Member -
Posted: October 08, 2007 at 2:23 PM / IP Logged
thank you...been looking everywhere for this info
Thursday, March 28, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
