08 Jeep Patriot Alarm/Remote Start Wiring
Welcome Guest :)
desh187
Copper -
Posted: October 27, 2007 at 12:49 PM / IP Logged
Has anyone installed an alarm on a 2008 Jeep Patriot.Needed wiring info to do an upgrade alarm system.
Thanks in advance.
KarTuneMan
Platinum -
Posted: October 27, 2007 at 1:22 PM / IP Logged
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| | This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Contact your interface module provider to find out if a bypass kit is available. |
12 VOLTS | RED / orange | Ignition switch harness | + |
IGNITION | Pink/white | Ignition switch harness | + |
ACCESSORY | Violet Brown | Ignition switch harness | mux |
| | Ground through a 600-ohm resistor to activate ACC and through a 180-ohm resistor to acivate starter. See the wiring diagram for complete wiring instructions. |
STARTER | Violet/brown | Ignition switch harness | mux |
TACH SIGNAL | Use a fuel injector | | |
FUEL INJECTOR | Opposite from BROWN / yellow | At any injector on engine | AC |
LOCK | Lt.GREEN/ dk.green (330-ohms) | In black 40-pin plug above driver's kickpanel | mux |
| | Ground through a 330-ohm resistor to lock the doors and through a 100-ohm resistor to unlock them. |
UNLOCK | Lt.GREEN/ dk.green (100-ohms) | In black 40-pin plug above driver's kickpanel | mux |
DOORPIN | SEE NOTES | | |
| | LF is violet/blue, RF is Violet/white, LR is Violet/gray & RR is Violet / YELLOW. All 4 wires are (-) and found in a 40-pin black plug above the driver's kickpanel. |
TRUNK PIN | Violet/orange | In the driver's kickpanel | - |
FACTORY ARM | Pulse Lock & Driver's doorpin | | |
FACTORY DISARM | Through OEM remote only | | |
BRAKESWITCH | Dk.GREEN / WHITE | At switch above brake pedal | + |
PARKLIGHTS | WHITE/ violet | Low in driver's kickpanel | + |
HAND BRAKE | Dk.GREEN / WHITE | At switch or behind instrument cluster in brown connector | - |
HORN | Dk.GREEN/ violet | At steering column or behind instrument clsuter in Black connector | - |
VSS WIRE | Dk.blue/orange | At PCM on driver's side fender under hood | AC |
KEY MUX | Violet/brown | Ignition switch harness | mux |
Wednesday, April 24, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
