2008 Trailblazer Alarm/Remote Start Wiring
carguy411
Silver - Posts: 683
Posted: November 13, 2007 at 10:24 AM / IP Logged
anyone have the wire codes for an 08 trailblazer. nebody done them yet are they simple also what all in one interface bypass do you recomend
thanks
carguy411
Silver - Posts: 683
Posted: November 20, 2007 at 11:34 AM / IP Logged
nobody has worked on an 08 trailblazer yet?
le me know
thanks
Twelvoltz
Platinum - Posts: 2,384
Posted: November 20, 2007 at 1:07 PM / IP Logged
Audiovox lists:
          #513732: 2008 CHEVROLET TRAILBLAZER 4DR SUV WITH 4.2L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          ORANGE          (+)          RADIO HARNESS
     Accesory          ORANGE          (DATA)          RADIO HARNESS
               THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON IS CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
     Ground          BLACK/ WHITE          (-)          RADIO HARNESS
     LF Speaker (+)          TAN
               THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
     LF Speaker (-)          GRAY
     RF Speaker (+)          LIGHT GREEN
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          DARK GREEN
     LR Speaker (+)          BROWN
     LR Speaker (-)          YELLOW
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          LIGHT BLUE
     Steering Cntrls          OPTIONAL
               THIS VEHICLE MAY BE EQUIPPED WITH ONSTARŪ AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES.
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          RED OR RED / WHITE          (+)          AT IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          AT IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          AT IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/BLACK          (-)          IN HARNESS IN DRIVERS SIDE WINDSHIELD PILLAR
               TO AVOID THE DOMELIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE,
     Domelight Super          GRAY/BLACK          (-)          IN HARNESS AT VEHICLE LIGHT SWITCH
     LF Latch          GRAY/BLACK          (-)          IN THE DRIVERS DOOR
     RF Latch          BLACK/ WHITE          (-)          IN THE PASSENGERS DOOR
     LR Latch          LIGHT BLUE/BLACK          (-)          IN THE PASSENGERS DOOR
     RR Latch          LIGHT GREEN/ BLACK          (-)          IN THE PASSENGERS DOOR
     Trunk Trigger          PINK/BLACK          (-)          AT MODULE IN REAR HATCH
               VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH
     Hood Trigger          PINK/BLACK          (-)          ON LEFT INNER FENDER
               NOT ON ALL MODELS
     Alarm Disarm          LT. GREEN          (-)          IN DRIVERS DOOR AT MODULE
     Parking Lights          GREY/BLACK          (-)          AT SWITCH
               OR BCM TAN PLUG PIN E5
     Low Crr Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Data Bus          VIOLET          (-)          AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
     Convenience
     Headlights-Lo          WHITE          (+)          IGNITION SWITCH HARNESS
     LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LAMP
     RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LAMP
     LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Pk Lt Bulb          BROWN / WHITE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     All Hazrd Lights          WHITE          (-)          AT VEHILCE HAZARD SWITCH
     LF Hazrd Bulb          LIGHT BLUE          (+)          AT FRONT LEFT TURN LAMP
     RF Hazrd Bulb          DARK BLUE          (+)          AT FRONT RIGHT TURN LAMP
     LR Hazrd Bulb          LIGHT BLUE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Hazrd Bulb          DARK BLUE          (+)          AT REAR RIGHT TAIL LIGHT ASSEMBLY
     Wipers-Lo          PINK          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          DARK BLUE          (-)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          LIGHT BLUE          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Seat Mem 1          WHITE          (+)          AT MODULE IN DRIVER DOOR
     Seat Mem 2          VIOLET          (+)          AT MODULE IN DRIVER DOOR
     Remote Start
     Ignition 2          WHITE          (+)          AT IGNITION SWITCH HARNESS
     Accessory 1          ORANGE          (+)          AT IGNITION SWITCH HARNESS
     Accessory 2          BROWN          (+)          AT IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSLOCK IIŪ ANTI-THEFT SYSTEM
     Anti-Theft Descript          PASSLOCK II
     Key Sense          LIGHT GREEN          (-)          AT THE STEERING COLUMN HARNESS
     Tachometer          UNCOMMON COLOR          (AC)          ANY FUEL INJECTOR NOT PINK
     Speed Sense          DK. GREEN / WHITE          (AC)          AT RADIO 24 PIN GREY PLUG
               OR PCM BLUE CONN. PIN 21
     Low Crr. Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Brake Lights          WHITE          (-)          AT BRAKE SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          GRAY          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Horn          BLACK          (-)          BCM TAN CONN. PIN E12
               ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT
     Modules
     WIRE          LOCATION
     Module 1          BCM-ATTACHED TO THE REAR FUSE BLOCK, BENEATH THE LEFT REAR SEAT
     Module 2          ECM-NEAR THE LOWER LEFT FRONT OF THE ENGINE
     Module 3          PCM-MOUNTED TO THE UPPER LEFT OF THE ENGINE
     Module 4          EBCM- FRONT DRIVER SIDE FRAME RAIL
     Doorlocks/Windows
     Databus Wire          VIOLET          (-)          AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
     Power Unlock          DATA BUSS SYSTEM          (REV)          AT MOTOR IN DOORS
               THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER.
     PowerLock          DATA BUSS SYSTEM          (REV)          AT MOTOR IN DOORS
     Driver Mtr Unlock          TAN          (REV)          AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B2
     Driver Mtr Lock          GREY          (REV)          AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B3
     Pas Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GREY          (REV)          AT MOTOR IN DOOR
     LF Window Up          DARK BLUE          (REV)          DRIVER DOOR MODULE
     LF Window Dn          BROWN          (REV)          DRIVER DOOR MODULE
     RF Window Up          LIGHT BLUE          (REV)          PASSENGER DOOR MODULE
     RF Window Dn          TAN          (REV)          PASSENGER DOOR MODULE
     LR Window Up          DARK BLUE          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     LR Window Dn          BROWN          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     RR Window Up          DARK BLUE          (REV)          REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     RR Window Dn          BROWN          (REV)          RERA RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Bypass
carguy411
Silver - Posts: 683
Posted: December 11, 2007 at 1:45 PM / IP Logged
does anyone know if that GM9 t harness will work with the 08 trailblazer.
and is there any tips or things i should look out for when installin on this new vehicle?
thanks for your help
installmarc
Copper - Posts: 49
Posted: December 11, 2007 at 6:48 PM / IP Logged
everything is the same as the 07's  just did two this week
carguy411
Silver - Posts: 683
Posted: January 28, 2008 at 11:26 AM / IP Logged
ok 2 things
i read somewhere that they dont need the starter wire hooked up for remote start is this true
also im going to get the bypasskit xk01 module
now do i have to specify which firmware i need or is it universal if i do which do i get
and has anyone had any sucess with the window rollup
thanks
carguy411
Silver - Posts: 683
Posted: January 29, 2008 at 12:02 AM / IP Logged
and one other thing i noticed the brake wire is neg do ihave to wire a relay for this or can i get it somewhere else
thanks
brcidd
Copper - Posts: 274
Posted: January 29, 2008 at 7:56 AM / IP Logged
I just checked the service manual brake switch schematic-- the white wire at the brake switch is still (+) positive as always with GM's-  of course you should test first to verify........
Brcidd - Engineer That Does Remote Starter Installs on the side.
carguy411
Silver - Posts: 683
Posted: January 29, 2008 at 12:03 PM / IP Logged
ok thanks for the help
also whats up with them saying you dont need to hook up the starter wire for r/s
thanks
brcidd
Copper - Posts: 274
Posted: January 29, 2008 at 12:24 PM / IP Logged
Newer GM's do not need a starter wire-- they "start" themselves-- if you ever drive one- you'll soon see that you just flick the key to start position and it does the rest-- no need to hold it there until it starts- likewise- there is no "grinding" of the starter- it doesn't allow that- (meaning- if you turn to key to start with enging running- nothing happens-- go ahead and try it)--
The start sequence is initiated by the BCM seeing both ignition on and accessory on at the same time-- then the accesorry drops out (while ignition is still on) and this is the signal for the BCM to activate the starter-- so cut away your starter wire output from your R/S- you don't need it- and let the R/S do the rest-- pretty nice with one less wire to hook-up-
--   also as a side note: I always go with the tach sensing for Trailblazers, Envoys etc-- due to voltage sensing goes inop in really cold weather- I had three comebacks last year over this complaint- finally read all about it at the Trailblazer forums......it is real tempting to go with voltage sensing- and increasing crank time etc-- but when it is ten degrees or less out- the alternator doesn't come online soon enough for voltage sensing to work........
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
