2008 ford taurus
Reeceddogg
Copper - Posts: 329
Posted: December 04, 2007 at 1:40 PM / IP Logged
Looking for the wiring info on a 2008 taurus.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 05, 2007 at 7:28 PM / IP Logged
Audiovox lists:
          #513342: 2008 FORD TAURUS 4DR SEDAN
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Please select another category
     Security
     Battery          RED          (+)          IGNITION SWITCH
     Ignition 1          WHITE/ ORANGE          (+)          IGNITION SWITCH
     Starter 1          BLUE/WHITE          (+)          IGNITION SWITCH
     All Door Trigger          GRAY/VIOLET          (+)          DRIVERS KICKPANEL
     Domelight Super          GREEN/ BLUE          (-)          DOME LAMP SWITCH
     Alarm Disarm          GREEN/ VIOLET          (-)          DRIVERS KICKPANEL
     Parking Lights          VIOLET/WHITE          (+)          AT SJB BOX
     Convenience
     Headlights-Lo          BLUE/WHITE          (-)          HEADLIGHT SWITCH
     Trnk Release          BROWN          (-)          DECKLID RELEASE SWITCH
               ON TARUS X GRAY / YELLOW ON INSTRUMENT PANEL
     Remote Start
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH
     Key Sense          BLUE/GRAY          (+)          IGNITION SWITCH
     Brake Lights          VIOLET/WHITE          (+)          DRIVERS KICKPANEL
     Horn          BLUE/WHITE          (-)          IGNITION SWITCH
     Modules
     WIRE          LOCATION
     Module 1          SJB BOX IS PART OF THE FUSE BOX
     Doorlocks/Windows
     Power Unlock          YELLOW/VIOLET          (-)          DRIVERS KICKPANEL
     PowerLock          BLUE/GREEN          (-)          DRIVERS KICKPANEL
     Driver Mtr Unlock          BLUE/GREEN          (+)          DRIVERS KICKPANEL
     Driver Mtr Lock          GRAY/BROWN          (+)          DRIVERS KICKPANEL
     Pas Mtr Unlock          VIOLET/GRAY          (+)          DRIVERS KICKPANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Reeceddogg
Copper - Posts: 329
Posted: December 05, 2007 at 8:22 PM / IP Logged
Anything on a bypass?
mikvot
Gold - Posts: 1,043
Posted: December 06, 2007 at 11:27 AM / IP Logged
It will need one. I use the key-overide sl2 by fortin.
Tuesday, April 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
