crackling sound through speakers, dome l
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105212
Printed Date: June 15, 2024 at 8:25 PM
Topic: crackling sound through speakers, dome l
Posted By: swanee
Subject: crackling sound through speakers, dome l
Date Posted: June 02, 2008 at 11:29 PM
Okay so i have an electrical problem that i cant seem to get to the bottom of. upon starting the car, there is a popping noice that goes through the speakers and the dash lights flicker on and then off. voltage reading with the car running is somewhere around 12.2-12.6, obviously way to low. with the car off and the key turned back, there is no power to anything, radio doesnt turn on, dome lights, windows, nothing. when locking the car the normal beep of the horn is very subtle, sounds like its muffled. headlights flicker when any high current is used(ie. power windows). dome lights flicker on and off with a clicking noise coming from the lower left kick panel, near the fuse panel....sorry for the long post but i just wanted to give all the symptoms so someone could possibly help me out. battery is brand new so it cant be that, i would think it would be the alternator but that shouldnt have any when the car isnt running correct??
thanks in advance,
chad
Posted By: Big Dog
Date Posted: June 03, 2008 at 7:50 AM
It seems like it's the alternator but before you swap it, remove battery terminals and clean them.
Verify ground wires from battery to chassis, it might be just a corroded cable. To test, start by charging your battery then put a booster cable between battery negative post and different ground points like engine, fender, frame, radiator support, etc and see if symptoms go away or if it improves.
Prepare your future. It wasn't the lack of stones that killed the stone age.
