2000 s10, starter issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140847
Printed Date: May 06, 2024 at 3:04 PM
Topic: 2000 s10, starter issue
Posted By: sshrader
Subject: 2000 s10, starter issue
Date Posted: February 13, 2016 at 6:38 PM
Hello everyone, I have came here wondering if anyone can help me determine what could be the cause of my problem, after many days of searching and testing, I have just gotten confused more.
I have a 2000 S10 2.2 L engine. I'm getting a no crank no start issue, so far what I have done, I replaced the Neutral safety switch, still nothing when turning the key, everyone lights up but starter wont turn over.
I tested from the igntion to the crank fuse, i get a light on my tester> from there I test the Purple\White wire on the Neutral Saftey switch. Here is the crazy part, I get a light, but when I touch the purple\white wire with my test light, the starter kicks over.
I even tested from the starter relay and I get light as well, I jumped the pins and tested that way.
But when I test the S post on the starter when turning the key no light.
Any tips would be helpful!
