2001 Nissan Xterra
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1419
Printed Date: May 13, 2024 at 2:19 AM
Topic: 2001 Nissan Xterra
Posted By: Ronaldo
Subject: 2001 Nissan Xterra
Date Posted: June 21, 2002 at 8:56 AM
Does anybody have the wiring diagram for a 2001 Nissan Xterra and any other remote start information?
Posted By: install_tech
Date Posted: June 22, 2002 at 8:34 AM
Remote Starter Wiring Colors and Notes | Function | | | Vehicle Color | Location | Start: | | | BLACK / YELLOW & GRN/YEL | IGNITION SWITCH HARNESS | Ignition #1: | | | BLACK/ WHITE | IGNITION SWITICH HARNESS | Ignition #2: | | | RED / YELLOW | IGNITION SWTICH HARNESS | Ignition #3: | | | N/A | | Accessory: | | | WHITE/ BLUE | IGNITION SWTICH HARNESS | Brake Light: | | | BROWN / RED | AT SWTICH ABOVE BRAKE PEDAL | Tach Signal: | | | PINK/BLUE | AT ECM, PIN # 3 OF 124 PIN CONNECTOR | Parking Lights: | | | BLUE/RED (+) | IN WHITE 8-PIN CONN. BEHIND SWTICH | Headlights: | | | | | OEM Alarm Disarm: | | | YELLOW/RED (-) | AT SECURITY MOD. PIN # 31 OF 36 PIN CONNECTOR * | OEM Alarm Arm: | | | YELLOW (-) | AT SECURITY MOD. PIN # 30 OF 36 PIN CONNECTOR * | | | | | | | | | | | | | |
Alarm and Keyless Entry Wiring Colors and Notes | Function | | | Vehicle Color | Location | Constant +12 Volts: | | | GREEN | IGNITION SWITCH HARNESS | Starter Kill: | | | BLACK / YELLOW & GRN/YEL | IGNITION SWITCH HARNESS | Ignition +12 Volts: | | | BLACK/ WHITE | IGNITION SWITICH HARNESS | Dome Lights/Superv: | | | RED / BLACK (-) | AT SECURITY MOD. PIN # 9 OF 36 PIN CONNECTOR | OEM Horn: | | | LT. GREEN/ RED (-) | STEERING COLUMN HARNESS | Power Lock: | | | LT. GREEN/ RED (-) | AT SECURITY MOD. PIN # 18 OF 36 PIN CONN | Power Unlock: | | | BROWN (-) | AT SECURITY MOD. PIN # 18 OF 36 PIN CONN | Trunk Release: | | | N/A | | Alarm Input Wire: | | | RED / BLACK (-) | AT SECURITY MOD. PIN # 9 OF 36 PIN CONNECTOR | Notes: | | * Security Module Can Be Found High In Driver's Kick Panel. Also look here: https://www.bulldogsecurity.com/wires/nissxterra00-01.htm Hope this helps. |
------------- install_tech
