PATS System Bypass, 2003 Ford Focus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145433
Printed Date: May 19, 2024 at 9:22 AM
Topic: PATS System Bypass, 2003 Ford Focus
Posted By: thisdirtywhiteb
Subject: PATS System Bypass, 2003 Ford Focus
Date Posted: May 28, 2019 at 10:37 PM
Can some one please give me a better understanding what tgis man is saying?
remove the ECU unit .then solder in a 12v supply from the on side of ignition,find a suitable connection in the wiring harness feed and solder to a switching transistor on the side of unit with a heat sink to the base connection of a transistor that controls the feed to another three transistors ,starter motor earth for relay,fuel pump earth relay,and ignition ,no relay and away you go.
------------- 've also used word like but you might consider that as applying to a character who tends to be easily annoyed, for example.
Its a 03 ford focus zx3 guys
