Long 90 Degree Ring Terminal?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145441
Printed Date: May 19, 2024 at 9:23 PM
Topic: Long 90 Degree Ring Terminal?
Posted By: tipsymcstagger
Subject: Long 90 Degree Ring Terminal?
Date Posted: June 04, 2019 at 2:27 PM
Pictured below is an OE battery cable ring terminal from a BMW. I am making new cables and the 90 degree lug I got from Crimp Supply is not as long between the center of the eye and the 90 degree bend as the original. Because of the design of the post this secures to, it's not laying in properly.
Are there 90 degree lugs available that are specifically longer before they bend? As far as I can tell, the OE lug is not an individual BMW part number. It's part of the cable assembly.
It's for 4 ga cable and a 5/16th post.
posted_image
Posted By: geepherder
Date Posted: June 04, 2019 at 7:47 PM
Maybe something like this:
https://www.quickcable.com/doclib/d1838.pdf
Date Posted: June 04, 2019 at 8:01 PM
I just measured the ones I already have (from Crimp Supply) and they seem pretty much identical to the measurements in that docuemnt.
But thank you for trying!
Date Posted: June 04, 2019 at 9:21 PM
Search Google for "long palm cable lug". If you look at the image results, you'll see a bunch of straight (not 90) blanks (no holes), but you may be able to bend/drill them. You'll likely have to order internationally as well. Lot's of results in Australia, UK, etc.
Another option would be making your own out of copper tubing. Here's one example video from youtube:
https://www.youtube.com/watch?v=RpFb_Yxl_hA
You could always tin them for a more factory appearance.
Posted By: Ween
Date Posted: June 04, 2019 at 9:39 PM
https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/12129598-L?qs=sGAEpiMZZMs7eK6h2EBtKiAPJPX6chA86aMitEmzmKs%3D
