First Time Installing Second Battery
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145686
Printed Date: May 17, 2024 at 4:46 PM
Topic: First Time Installing Second Battery
Posted By: sethwilliams88
Subject: First Time Installing Second Battery
Date Posted: October 14, 2019 at 12:39 PM
i have a new optima red top 34/78 and I just bought an Xs power D 3400. So can I hook those two batteries up in parallel, do I need an isolator hooked up? And do I run a wire to each battery for my alternator I have a high output alternator I just don't know how to hook everything up I've tried looking at other posts and don't understand if one will draw from the other please help and if those won't work can somebody please suggest a budget-friendly battery to put under the hood
------------- Seth
Posted By: mgoetz74
Date Posted: October 14, 2019 at 2:28 PM
most definitely use a isolator. If you hook them up with out one the alternator will try on charge both at the same time puttin extra stress on it. Since the 2nd battery is primarly use for extra key off time you won't run down both battery and still be able to start your car
------------- 33 years as a installer now just a retired old guy. Favorite thing to install/topic are remote starts/car alarms. Stop using test lights!!!
