When to use soldering?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24013
Printed Date: May 16, 2024 at 9:36 AM
Topic: When to use soldering?
Posted By: mindctrl
Subject: When to use soldering?
Date Posted: January 05, 2004 at 8:24 PM
I was just wondering... when working with car wires and making a connection... When is it best to use a connector, and when is it best to use soldering?  Are there any special cases where you should use one or the other?  Thanks.
--mindctrl
Posted By: mikeshonda750
Date Posted: January 05, 2004 at 9:04 PM
Well... im a solder type guy... when should you solder? always. If and when you get good at it, soldering is about the same speed, less costly, more effective.
Using crimp caps butt connectors and twist/tape? you should use soldering... always... heh j/k... use soldering whenever resistance is key.... wiring up a relay to bypass a passlock2? yep... gotta be within 1% of the value you find.... so if you NEED 1kohms resistance for the vehicle to start.... you have 10ohms to play with.... a bad connection can suck up 10ohms like nothing... soldering correctly you will loose zero ohms, making the resistance the same ALL THE TIME, not just when its warm out and the resistor/wire feel like working
Posted By: joeyspc
Date Posted: February 14, 2004 at 4:51 PM
I always solder EVERYTHING. That way you will never have a doubt...
Posted By: Teamrf
Date Posted: February 14, 2004 at 5:59 PM
All the time..Crimp caps, and T-Taps are just so unreliable. Make sure you get a good solder connection, and tape it up.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: SOUND PRESSURE
Date Posted: February 15, 2004 at 2:20 AM
I agree, I always use solder and heat shrink tubing.
Sound Pressure
