I have a few questions about cigarette lighter plugs and inverters.
How many watts of 110 can you draw from an inverter plugged into a cigarette lighter? I think its 150 watts, but I need to know for sure.
How clean is the power coming out of an inverter going to be? It needs to run a laptop, so I would imagine it has to be good, but I don't know. Is a surge protector enough? Can you recommend some decent inverters?
Is 150 watt going to be plenty for a laptop and a small sub/sat speaker system?
I appreciate responses
-Chris
2001 Suzuki SV650
To figure output, multiply 12 * size of the fuse for the lighter. Watts = volts * amps, so 12v * 10 amp (fuse) equals 120 watts.
Even the cheap inverters from places like Sams Club and BJ's will work ok with a laptop power supply..
The only way to know how much these items consume is to measure them.. use a DMM and measure AC amps.
The inverters I use are from BJs.. Sam's Club has similar ones also.. Last time I checked at BJ's, the 700 watt unit was $40.. the 350 watt unit was $24.
Hope this helps,
Jim
Yeah, thanks.
I might find out by looking at the specs for the laptop too... duh
-Chris
2001 Suzuki SV650
Be careful when using the dataplate to determine if an inverter can power a specific device.. AC power has a component known as Power Factor. I have a coffee grinder that's rated at 60 watts, but because of a truly horrid power factor the grinder draws in the neighborhood of 5 amps.. which can't be supplied by my 350 watt inverter. Do a google search on 'power factor'.. interesting stuff.
I imagine that any meter that can measure DC amps should be able to measure AC amps.. just be careful. You can buy inductive meters that don't require you to break the circuit.
You can buy inverters now at places like BJ's and Sams Club for something along the lines of a 350 watt unit for $24, a 700 watt unit for $40, and a 1000 watt unit for $80.
Hope this helps..
Jim
