hey im looking for the wiring diagram for an oldsmobile 2001 intrigue..
any help is greatley appreciated
| 12V|red |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|green |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| POWER LOCK|RED / black |- |drivers kick panel or BCM *1|
| POWER UNLOCK|ORANGE / black |- |drivers kick panel or BCM *1|
| LOCK MOTOR|gray | |drivers kick panel or BCM *1|
| UNLOCK MOTOR|tan | |drivers kick panel or BCM *1|
| DISARM DEFEAT|tan | |passengers kick or BCM *1 |
| PARKING LIGHTS +|brown | |headlight switch |
| PARKING LIGHTS -|white | |BCM *1 |
| HEADLIGHTS|tan |- |headlight switch |
| DOOR TRIGGER|blue and blu/wht |- |BCM *1 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|ORANGE / black |- |BCM *1 |
|TRNK/HTCH RELEASE|brown |- |switch or relay *4 |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|*2 | |*2 |
| SPEED SENSE|GREEN / WHITE | |PCM *3 |
| BRAKE WIRE|white |+ |brake pedal switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|green(L), gray(H) |+ |steering column |
| LF WINDOW UP/DN|blue - brown |A |drivers window switch |
| RF WINDOW UP/DN|lt blue - tan |A |drivers switch or kick panel|
| LR WINDOW UP/DN|green - purple |A |drivers switch or kick panel|
| RR WINDOW UP/DN|lt green - purple |A |drivers switch or kick panel|
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|BLACK/ white |- |radio |
| RADIO SWITCH|yellow |+ |radio |
| RADIO ILLUMINATE|BROWN / white |+ |radio |
| POWER ANTENNA|green |+ |radio |
| LF SPEAKER|tan - gray | |radio or speaker |
| RF SPEAKER|lt. green - green | |radio or speaker |
| LR SPEAKER|brown - yellow | |radio or speaker |
| RR SPEAKER|blue - lt. blue | |radio or speaker |
Notes:
Note: This vehicle has the passlock II immobilizer system that, when adding a remote start. *1 The BCM is under the driver side dash to the left of the steering column. *2 For tach go to any of the injectors and use the wire that is NOT pink. *3 The PCM is located in the front drivers side of the engine compartment in the air cleaner assembly. *4 The trunk release relay is behind the glove box.
No problemo
