94 cutless ciera wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41174
Printed Date: May 23, 2024 at 11:51 AM
Topic: 94 cutless ciera wiring diagram
Posted By: shortie
Subject: 94 cutless ciera wiring diagram
Date Posted: October 18, 2004 at 7:31 PM
need the diagram for a remote start for this car.
Posted By: Teken
Date Posted: October 18, 2004 at 9:52 PM
DIRECTWIRE™ WIRING INFORMATION - OLDSMOBILE / CUTLASS CIERA / 1994 / Remote Start
12volts red + ignition harness
Starter purple or yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue + near underdash light
Power Unlock white + in 3 and 8 pin plug
Lock Motor
Unlock Motor
Parking Lights+ brown steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger -
Notes: Must go to each door to avoid dome light delay and/or alarm falsing from the dome light check circuit. For the drivers door, use Lt. GREEN/ black in the drivers kick panel. For the passenger door, use Lt. blue in the passenger kick panel. The rear doors have pin switches. Must go to each rear pin switch and diode isolate the factory wire a six amp diode. For rear door trigger attach between the diode and the pin switch. Each door trigger wire must be diode isolated to the alarm.
Dome Supervision
Trunk/Hatch Pin gray - rear dome lamp
Notes: Only available on the wagon models.
Hood Pin
Trunk/Hatch Release black + release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer AC ignition coil module
Notes: Use white or orange on the 4 cylinder motor, and PURPLE / white on the 6 cylinder motor.
Wait to start
Brake Wire yellow + brake switch
Parking Brake
Horn Trigger black - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Regards
EVIL Teken . . .
