Cordless Soldering Iron
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42024
Printed Date: May 13, 2024 at 4:44 PM
Topic: Cordless Soldering Iron
Posted By: bdl666
Subject: Cordless Soldering Iron
Date Posted: November 01, 2004 at 2:26 AM
Does anyone here have any experience with this? Or something like it? https://https://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=370-220 Does it get hot enough to solder 2 12-14gauge wires together?
Posted By: audiopro111
Date Posted: November 01, 2004 at 9:06 AM
your talking about the yellow one right the one that sits in a charger ? i don't see why not according to it's specs. But the ? is how convinient is it are you a profesional installer that uses it all day .are you steady in one location at all times that u can keep the charger plugged in it at all times or are u a traveling installer that keeps it on a power supply in your vehicle ,another thing i noticed it doesn't say anything about being able to adjust the temp. range.If your not going to use it often go for it. I personaly use a butane powered one made by blue point with adjustable heat range it also comes with a torch,hot knife,and heat shrink tip with are constantly used.... And yeah it would solder 2 12-14 gauge wires together! ------------- AudioPro111
Posted By: brianrwebb
Date Posted: November 01, 2004 at 3:33 PM
I personaly use a butane powered one made by blue point with adjustable heat range my friend, do you have a link to give out for this blue point butane soldering tool you use, on the web? was curious as to what it looked like and its price. thanks, Brian.
Date Posted: November 01, 2004 at 7:35 PM
yeah u can get it at snap-on.com they have just the butane soldering iron or the full kit buane soldering iron it ranges from about 40 to 100.oo dollars.
Posted By: bdl666
Date Posted: November 02, 2004 at 1:49 AM
I just want to use it for the occasional remote starter install. But I mainly want it for work where I have a lot of machines to take care of, and no outlets close by. I hate dragging the extension cord and then have to wait for the iron to heat up. I could use a soldering gun (the 100/140 watt) but I will still have to drag the cord.
Date Posted: November 02, 2004 at 10:15 PM
go with the butane powered one
Posted By: auex
Date Posted: November 02, 2004 at 10:26 PM
Bluepoint soldering iron, YAS1------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: forbidden
Date Posted: November 04, 2004 at 7:58 PM
OK, how many of you have wanted to kill your Snap-On butane solering iron because she just won't heat up. Is it the type of butane that you use or is it just a smelly POS? I've gone through 3 of these things and just now I have been informed that I must use this type of butane (conveniently sold by my Snap-On dude). ------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: auex
Date Posted: November 04, 2004 at 8:01 PM
I use only ronson butane. I have used cheap cans before and it clogged the soldering iron, I guess it isn't filtered as well. First one lasted a year, second one is going on 2+ years.
Date Posted: November 04, 2004 at 8:09 PM
u don't have to use a specific type of butane for snap-on just that the ceramic under the soldering tip gets dirty so it doesn't allways turn on so just use a small awl and scrape the ceramic a little to clean it out and it will work like new again........but ronson is my favorite......
Posted By: Teken
Date Posted: November 07, 2004 at 1:13 PM
I just purchased another unit from Weller, it is almost the exact one from Snap-On. The only difference I know of is the lack of 3 more soldering tips.
I have shopped around the entire Internet, and this is by far the best price $59.99 USD, I have ever seen for the kit.
https://www.sacelec.com/cooper/weller/cordless_solder_irons.html------------- Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
Posted By: Teken
Date Posted: November 07, 2004 at 6:27 PM
Rob,
If you want some Ronson butane, I can get them for $3.49 CDN, $3.98 with tax's.
They are 5.82 oz cans, so let me know. Anyone who needs some, can also PM me, and I will send them out, ground shipping only.
EVIL Teken . . .
Posted By: stavy customs1
Date Posted: November 09, 2004 at 2:20 AM
I got mine from matco and it cost me 110 bucks and it sucks. Ive gone through alot of tips and i always clean them off after im done using them. Yes they do come with a warranty but the tip does not!!!!
------------- Best Buy Installer
Posted By: eric_the_great1
Date Posted: December 11, 2004 at 2:11 AM
I use a Weller Portosol. It works great for me. Once you lose the cord, you never go back!!!
